SKYLINE WONT START ! HELP !!
So hear me out first guys, hear the full story it might help !!
i changed my Blitz Pod filter to a K&N one
Car was running fine, and on my way back home I decided to give it abit in the tunnels, after giving it all the sudden my car started choking or chugging and I thought my engine died, but it was still running, it runs fine till I step on the pedal half way it chugs and struggles and pretty much wont let me Go over 3,000 RPM so I thought maybe it's the POD that's acting up the AFM cause it felt like it was the case.
So the next day I changed it back to the Blitz that I originally had earlier on and went to drive it around and it was back to normal "woooooooo" and as I got close to home it did it again the chugging and choking like it was gonna die, so I was f.. could it be my spark plug or coils.
So the next day I changed my Spark Plug, it was a BKR5EIX-11 which isn't recommended but I had it laying around so I replaced it, my old spark plug was black and burnt on the tip so I thought yeah maybe this should do the trick!
Plug everything back in and....
it CRANKS AND STARTS FOR A SPLIT SECOND AND immediately dies out and I only have one conclusion left, the Coilpacks but I want to see what you guys think
-every hose is plugged in correctly and tightly
-strange thing is that before I change the spark plug the car was running but a weak start up so I thought Spark plug but now I don't even know anymore.
PLEASE HELP ME GUYS !! Could it be the coilpacks ?? Could the spark plug have anything to do with it, even if it's not recommended it should still start up, it's gapped at 1.1 which is how the plugs came (Bkr5eix-11)
https://www.sau.com.au/forums/topic/467861-skyline-wont-start-help/
I replaced it with bkr5eix11 cause I had it sitting in my rooms for years for my NA/R34 which was recommended. And nah doesn't seem like a fuel issue, I got half a tank and I can definitely hear the fuel pump just before starting the car
From what we can tell the only thing changed was the filter, I would look at the Maf extensively to check for damage.
My car would not start and sputtered going into boost when the plugs were fouled. Also check for ground wire to coil packs/ignitor.
Have you considered that it could coincidentally be an alternator or battery that is no good? It's a big leap, but you should probably just check how many volts you have on the battery terminals before and during cranking.
33 minutes ago, Jonic said:
The ecu is stock and fuel line is good, I think it's the AFM since I change the Pod around and maybe it bounce around too much and played up perhaps
Well just unplug it and see if it starts.
LOL so I tried starting her up after work and guess what, it started weak and actually stayed on, Tried it again 10mins later and wallah it's starting up and running all good again ! Haha what a confusing moment, what in the world happen ??
Now everything it out back together the car runs but the PROBLEM OF THE LIMP MODE IS STILL THERE !! I can't even rev pass 2000rpm, even when parked! Something must be playing up and I'm thinking it's the AIR FLOW METER. Ever since I changed the Pod Filter the problem started, but the thing is I changed it back to normal but it's still limping, I can't even hit 60Kms on the road :0
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
