On 12/1/2016 at 11:20 PM, Jonic said:
Now everything it out back together the car runs but the PROBLEM OF THE LIMP MODE IS STILL THERE !! I can't even rev pass 2000rpm, even when parked! Something must be playing up and I'm thinking it's the AIR FLOW METER. Ever since I changed the Pod Filter the problem started, but the thing is I changed it back to normal but it's still limping, I can't even hit 60Kms on the road :0
When my MAF was bad the car wouldn't rev past 3000rpm, it made my car run rich and when I changed the MAF it did not run right as the plugs were fouled. Thoguht I would share that. Pull the MAF sensor plug while the car is running, should make a difference on AFR's, idle speed etc.
Haha dam but did the problem happen as soon as you start the car up ?? And I'm thinking of buying a New AFM and replacing it. I've tried spraying it down with electrical and contact cleaner but nope seems the same when i take it for a drive.
1.It would drive Fine past 60kms till it gets a little warmer or after 3mins and then BAM it just won't let me rev past 2000rpm and i'll be limping the car home on 40kms LOL !
2.Then turn off the car, and turn back my ignition on and i got my A/T light flashing :O !  after about 10mins, I start the car up and its back to Normal
Then repeat 1.
Weird problem, it could be the AFM because it previously had a BLITZ POD filter and i swapped it for a bigger K&N POD filter. After I changed it that night i went out for a quick drive and climbed to 100Kms safely while going hard and after a RED light ( car was idling fine ), when i accelerated it wouldn't let my Rev go past 2000RPM, i thought at that moment my car just died on the spot !
After that went home changed New Spark Plugs and Coil Packs cause I thought that was the problem but NOPEE. Still happening ):
So I got a scanner and got what says : A/T CVT Fault & ABS/VDC Fault, I believe it's the AT because my transmission is jerky and pretty clunking and it puts the car in Limp mode so it doesn't damage the car from what I heard. Any thoughts ??
Car starts up now, sounds perfectly fine but at occasions after 10mins of driving when on idle or when driving the rpm drops slightly and starts to shudder like the car is about to die and the rpm goes back to normal sitting at 1000rpm. any thoughts ??
CHANGED : Spark plugs, Coils, New AFM, Fuel Filter. No visible vacuum leak, cooler hose or tight with clamps. I'm lost :(
Took it to the mechanics and there clueless, went to 3 different places. They got the same code but are clueless why it's having trouble starting. Have to push the pedal in every morning start up. Am randomly car struggles with revs then shuts down when at a red light. Car idles perfectly at 1000 when warmed up no hesitation or shaking only until when it's warm up it will randomly just drop revs like it's about to die on me
Went mechanic today, turns out my transmission hose was bent too much and stopped the fluid from going through so he replaced it, and did a clean on the idler valve. Car has been running beautifully, no stall or any random vibration, that's probably why the A/T fault was on the OBD2 scanner. Brilliant.
  • Like 2
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
