I called into the auto trimmers and dropped off my door skins. The original interior is in really poor condition and it's blue anyhow so it all has to go. I've had a lot of trouble finding fabric to match the original vinyl but I think the pattern I've chosen should look pretty good once the whole car is trimmed.
These are the fabrics I've chosen.
  • Like 1
Alan sourced some 3mm dense rubber to fit behind the vinyl to replicate the original depth around the stitched areas. Without it the panels would have looked too one dimensional and the stitched detail would not be as visible. One problem we found was that the bright work on the top of the passenger door was damaged, it looks etched. I had to track down some replacement door trims to cannibalise for parts.
One mistake I did make was I thought the GTR had a carpet base on the door skin, turns out it does not but hey at least it will stop the scuffs when I'm getting in and out.
  • Like 3
I picked up a LD28 crank years ago when they were the in thing for building 3.1ltr stroker motors, not sure that I'll go down this path as there has been so much development since then but it's still handy to have.
I picked up a set of fully Restored Triple 44mm Mikunis restored to factory new condition in 2012.
Genuine Mikuni Manifold & Linkages
Genuine Mikuni 50mm Trumpets
Genuine Mikuni Soft Mounts
All new jets, pump diaphragms and gaskets etc
All hardware replated
  • Like 4
3 minutes ago, PranK said:
Jesus, that interior!! :O
He did a fantastic job, very reasonable price too.
I removed more of the dash and fittings from the car. I also had a play with a spare cluster surround I had to see how easy it was to remove the wood grain finish. As some of you might be aware, underneath that wood grain trim is the raw aluminium finish used in the GTR. Obviously the same piece was used, it was simply covered for the non GTR models.
It turns out thinners or gun wash is very effective! I tested this on my spare piece and it worked a treat. The only common problem is a lot of pieces have corrosion "worms" in the finish. I'm not sure if this is a result of the trimming process? The first piece I tested was petty and I thought perhaps I'd make a mitre box and try and re-brush the alloy but it just didn't look good.
I decided I'd remove the second panel more carefully than the test piece so I wouldn't damage or bend the alloy. I tried using a heat gun but it's not fantastic. It looks like a contact adhesive is used on the back of the alloy panel to fix it to the plastic. I ended up pouring some gun wash in between the alloy and the plastic and then waited for it to dissolve the glue. Not great for the plastic but I do have a spare which I plan on spraying.
Once the alloy was off I made up a make shift bath with foil and left the piece if for about 30 mins or so.
Once the thinners does it's work the wood grain cover is reduced to a balloon like rubber and simply peels off. It's a bit tricky to get off the edges but with some care it all comes off.
The contact adhesive also peels off the back
Once all the glue and rubber is removed, if you are REALLY lucky you might fine a virtually perfect aluminium panel like I did. It's still a bit grubby in this pictures so I'll brush it with some more thinners tonight and give it a good scrub. It has some very minor corrosion spots but I'm not going to both fixing them, if anything we may try and clear it.
I pulled the cluster and gauges from the car when the interior came out. I'm always amazed my how much dust I find and where I find it. I guess I have to remember the car is 41years old, older than me! Anyhow I wanted to clean and service the lot, make sure that they were OK electronically and reset the ODO as the car is really being reborn, so it deserves 0 on the clock.
I've removed the clock on these as the GTR's had a 'Nissan' blanking plate instead of the clock.
Reset the odometer back to 0, looking much cleaner now too.
I cut and polished up all the lenses, cleaned the housings, dials and needles, checked the circuit boards and components and then reassembled the lot. I'm trying to decide if I change the globes out for LED's or stick with bulbs for the warm glow they give. It's interesting how the bulb housings are painted in certain areas to restrict where the light shines. I think I'll have to play with this and see what looks right.
  • Like 1
I ordered some replica fuel cap and breather covers from Japan which were great but no where close to fitting so I had to sand them down. I found a new lock mechanism and key then I had mounting hardware electroplated and reassembled to finish them off.
We pulled the glass out over the weekend and the rest of the interior. The windscreen wasn't too bad, it obviously been replaced before because the sealant was still quite soft and workable. I used the heat gun and knife and managed to lift it out pretty easily in one piece, too bad it's chipped and needs to be replaced anyhow. The rear glass was a different story, the sealant was seriously hard and they heat gun didn't do much other than set it on fire.
My dad came up with the great idea of using his new Makita Mult-tool to cut though the sealant. It cut like a hot knife though butter, I would have been there for hours doing it by hand otherwise. We got the rear glass out with no scratches or cracks, I'm not sure if rear glass can be sourced?
I still have to clean up around the windscreen but both the front and rear seem to be in pretty good shape with only some very minor rust at the rear. On the drivers side there is a few clip mounts missing and some pin holes that will need to be fixed.
The inside looks pretty good too, some minor rust in the rear foot wells where water has sat around the drain holes and some surface on the sides but I'm very happy with the body so far.
  • Like 2
Being the glutton for punishment I am, and wanting to use as many original parts as possible, I decided to bring in a rusty GTR grill I found in Japan. It was a lot cheaper that most I've seen going at around AUD $700 and considering a replica grill is close to AUD $600 I figured it was good value. I knew I was going to have to do some work on it but I wasn't sure just how much. I picked up the grill from Aaron at Import Monster and it was VERY rusty!
The top and back aren't too bad but the bottom is worse than I feared and will need to be replaced..
I'm not too fussed, I'll drill the pop rivets, dismantle the entire grill and then send the salvageable parts away for acid dipping and zinc plating. I'll take the bottom piece into a metal fabricator and hopefully they can knock me something up. Fingers crossed!
2 minutes ago, PranK said:
I want one of those multitools!
You're doing a fab job of stopping me working today. I hope you're happy.
They are brilliant, I've got 8 years of content to update here so best buckle in... ;)
  • Like 1
1 minute ago, Anfanee said:
Oh god.....
I have work to do. Can you do this on the weekend?
Its too late man... That ship has sailed. We're committed now.
  • Like 2
I had some used and NOS parts arrive...
A mint light cover, these are usually cracked and discoloured
Some black grab rails for the new black interior
Some NOS switches for the dash
And a NOS gear boot, choke cable and skyline badge for the dash.
And new rubbers for the window divide and bonnet.
I also picked up some power window mechanisms and switches. I'm missing a rear mech though. Not sure if I'll fit these yet or not, could be cool though.
  • Like 1
I stripped more parts of the car including the dash and send a bunch of stuff off for plating and powder coating. A bunch of parts also arrived...
New washer bottle
New fuel cap
New indicators
New steering column cover
One part of the door seals
And some new window seals for the stainless trim
I'm trying to track down some replacement weather seals for the stainless trim that sits on the top of the doors and the base of the small rear coupe windows. Not sure where I'm going to find these.
I had a chat with Jalopy when I was at 2day Nostelgic this year and I got the impression they were starting to reproduce more C110 rubbers so fingers crossed!
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
