My 1975 C110 Skyline Restoration
12 minutes ago, mlracing said:
Ohh this is yours haha, I was the one asking about the newspaper lol. Genuine query actually as my Hako has some in it haha
Haha, didn't realise that was you! There is some amazing shit under classic car skins. I knew this one was bogged, they all rust there. At least they cut the rust out and sealed the cavity to prevent further issues I guess :)
  • Like 1
  • 3 weeks later...
Now the body is back from media blasting we get a good look at what we're dealing with. I'll fly up to Adelaide next week to take a look in person. The plan to date is the rear quarter panels and rear beaver panel will most likely come off.
Yeah mate, it's quite standard. More holes that I was expecting in the bonnet, boot and doors but all pretty standard. At least it's going to be done right and wont rust from the inside out :)
  • Like 1
Flew up to Adelaide yesterday to take a look at the car, it's amazing how a media blasting and primer is enough to get excited. Progress! I spoke with Paul and we agreed the quarters, roof and rear beaver would now come off. A few pics...
The wheel arches have been marked for cutting to fit the flares, new tubs will be fitted with the quarters off. We'll weld in nuts behind them so the flares can be bolted on neatly with hex nuts.
Plenty of rust at the base
And off with the roof...
  • Like 4
Paul has started work on the rust replacement sections, this is the drivers rear quarter panel.
Approx 10 hrs to make these 4 panels. Lower sections for LH and RH 1/4 panels. These are just roughed up and will need fine tuning prior to Oxy welding on.
  • Like 3
Wow, the guy is an artist!!!
It seems to be a dying art to hand fabricate components like that.  Awesome to see!
I'm glad it's you footing the bill not me!!  Can't wait to see the finished result though.
  • Thanks 1
Yeah pretty impressive huh! Might be $$ but it will be worth it in the end :)
1 hour ago, VFRegal said:
Saw the pictures on facebook. Fantastic work.
Will be amazing once finished.
Yeah it's all moving pretty quickly now which is exciting. Should hopefully have some photos of the car with the entire rear end off and the tubs going in etc.
I saw some original Nissan/Datsun manuals at a second hand shop the other day while on holidays. There were heaps of them there. Let me know if you wanted details of the place.
  • Like 1
The flares were trial fitted to mark the quarter panels prior to removal
Once the quarter panels were off we get a good look at the inner panels which are in pretty good condition
The edges of the boot were of course covered in the same gunk as the rest of the car, now the panels are off it will go back to media blasting for a further tidy.
    • Hmm. Was quite a few years ago now. I think I bought from a crowd in the US called CDT Audio. The speaker is the HD-6. The HD-6CF would have been the better option (based on T-S parameters), but they were discontinued in 4 ohm at that point in time. The HD-6 is a better driver in almost every other way (than the CF) - just not as good in IB. They still do the HD-6. They might even have a more suitable (for IB) option here.https://www.cdtaudio.com/cdtnew22/products/components/woofers/midwoofers/midwoofers.htm But, here's the rub. I was working in the US a lot back then, so I got them delivered to my US office and then just brought them back to OZ myself. I don't know if they will ship to OZ, and it probably wouldn't be great cost-wise anyway. As to results. They're driven direct off the rear channels of my headunit, because the headunit can be setup to run the rears as subs. So, not a lot of power being fed there. Nevertheless, there's no shortage of volume - the sub levels don't need or want to be boosted at all. The bass is definitely not what you would call "tight". It is definitely a bit delayed compared to a proper sub. But, with the great front soundstage and really good 6.5" woofers in the front doors, I'm getting most of the bass detail from the front and the rear is really only to extend the bottom end a bit. Works for what I'm doing. I mean - until recently you couldn't really hold a conversation in my car due to the fuel pump, and for many years I had tyres so noisy (Kumho KU36 at <50 tread depth) that I had to drive with earplugs anyway!
    • curious to know what drivers you chose and the results? quik mafs, says two 6.5s should roughly equate somewhere between a single 8" or 10" driver. i agree that IB is definitely the way to go in most cars imo.
    • S13 and R32 rear suspension geometry is horrible once you lower it (which everyone does). The camber & toe out ramp is very aggressive, hence it's common for the S13 boys/girls to use a S14 or S15 subframe as the geometry is light years ahead. I'm sure the same can be done on R32s, but I don't know anyone that has done that.
    • Well, of course there's something wrong with the suspension. It was like that when it came out of the factory. Nissan wanted it to ride at least 50mm higher than most of us. They wanted it to be comfortable enough that the press and user reviews didn't complain about fillings being knocked out of teeth. The marketing people wanted to be able to talk about their fantastic new 4WS system (even if it was a pointless exercise, ha! pointless! Do you see what I did there? no? oh well. too bad). There weren't any semi-slicks or semi-semi-slicks or 18" wheels. Laser pointers didn't exist, so you couldn't easily build a bump steer gauge. There wasn't any better technology for suspension bushes than squishy shit in a condom. The list goes on.
    • I personally recommend not messing with factory suspension until you can clearly identify something wrong. For example I think the R33 might need some way to adjust front camber because I feathered the edges of the tires much more than the center of the tread doing some figure 8s and slalom.
