Picked up the short motor last weekend. I supplied the L24 front sump and oil pickup as the L28 has a rear facing sump and oil pickup so the block needed to be modified to suit.
I also had a clutch supplied with the motor as the flywheel face has been designed around the pressure plate and it’s balanced with flywheel. It's a a single plate unit consisting of a 2600lbs AP pressure plate with an Exedy organic race clutch plate, built by Jim Berry in QLD.
I've listed my Mikuni 44mm carbs and LD28 crank for sale and once they move I'll send the short motor back with the P90 head to be completed. I spoke with Jenvey about the 48mm heritage bodies and they wont be in production until March so I'll follow up then.
  • Like 3
  • 3 weeks later...
  • 1 month later...
Update time... The body is now booked in with Custom and Classic Cars for body work but probably wont be started until the end of this year due to the work they have on. I've seen quite a few projects they've worked on including another C110 and 240Z and the craftsmanship is outstanding so I'm confident the car is in good hands.
C110 -https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=522151214472678
240Z - https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=1328888837132241
I purchased the body kit from Restored which includes the over fenders, rear wing and chin spoiler and a few more missing rubber seals.
The other big purchase is the fully built P90 head to match my 3.3ltr short block. Turns out that Locky from LCR is taking a different direction with his 240Z (matching numbers L24) and offered me the head that was built to match. Specs are:
  • New 46mm Stainless Intake Valves.
  • New 35mm Stainless Exhaust Valves.
  • New Valve Guides.
  • Refaced Rockers.
  • High-side Steel Retainers.
  • HSD valve springs.
  • 54.5cc Chambers.
  • Manifold face has been drilled & tapped for an LCR external coolant rail - blanking plates included.
  • Injector notches have been welded up.
  • New Freeze Plug.
  • New Nissan Oil Gallery Plugs.
  • New Nissan Rocker Cover gasket.
  • New Kameari MLS Head Gasket.
  • Near-new Rear Collant outlet
  • Water Jet Blasted Head & Tappet Cover.
Ported by Les Collins at LCR Racing, Intake port flow (average): 228cfm @ 28" of H20 on a 90mm bore plate. This head flows enough to make 380hp at the flywheel so it should be a very strong motor for a little C110.
  • Like 4
  • 1 month later...
  • 11 months later...
So, I hope you're sitting down for this news... I'm dropping the car off for body work next weekend! It's finally happening. The shell will go on a trailer and I'll do a weekend road trip to SA. There will be lots of progress shots on body work and I'll be busy again with the car.
  • Like 3
I made the 1500km round trip from Melbourne to Mt Barker in South Australia over the weekend to drop the car off for body work. ETA on the job is approx 8-12 months but I should get some regular updates which I'll post. There is lots to do whilst I'm waiting, engine assembly, sourcing induction and ECU, gearbox, diff, suspension brakes etc. All of the running gear will need to be blasted and painted and there is lots of work to do on the final parts removed like the heater, aircon, steering column....
Getting a non rolling shell on a trailer is pretty tricky work!
We left super early for the 9 hour drive
The car looked a little sad sitting there but it's in very good hands
I dropped the GTR grill off for reassembly and painting and the GTR rear panel too as it's painted in acrylic at the moment.
On 27/04/2018 at 12:31 PM, Adzmax said:
lolol my favourite line
"Serious buyers only! I can’t stress this enough I know what these are worth. Don’t waist my time"
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
