3 hours ago, SiR_RB said:
That's correct
tuned at jez and ran 140mph ?
About 448kw at 24psi
If my stupid build ever finishes or if I don't rage quit and burn the lot I'm going to try beat that mph :)
If my stupid build ever finishes or if I don't rage quit and burn the lot I'm going to try beat that mph [emoji4]
Cheer up sunshine, you're on the home stretch now. You just gotta keep it together a little longer[emoji12]
26 minutes ago, SiR_RB said:
How far off are you mate
Just need the injectors to fit somehow, plenum on, redo the entire oil system (as the old one was filled with bits of metal) and then slot the lot in.
Honestly over it :(
Man you need to harden up, this has been a small and quick build by comparison to what goes on around here.
Stop being so precious, it will make it easier when it throws a rod on the dyno ;)
Okay so besides the fact I can't seem to get ever so popular 1/2 height with extension injectors on, I decided to bend some left over strips of aluminium to fit my obsessively large 25 row Setrab oil cooler than cost as much as my kidney.
Will redo the brackets again once I'm happy with fitment.
(Yes that's a bit of cable ties on the rear end lol)
20171216_185644_HDR.thumb.jpg.1cd07c9a1883327072ee5a83fb601876.jpg20171216_185620_HDR.thumb.jpg.5fe58dc3aa4ff0043838c1b9467f152f.jpg
My injector woes in a thread:
Long story short - don't try and fit 1/2 height injectors to a RB25 NEO intake manifold. Even though they're at the right height using extenders blah blah blah they don't fit. All resellers will tell you they fit, they don't. They are wrong, I am right.
  • Like 1
Serious note, if anyone wants to take my car/motor/tools/spares the lot.. I will trade for a BMW 335i F30 or E90 (must have N55 motor) in auto.
Over it.
BMW must have less than 70 000 km/h
Nearly defeated but as son of immigrants I will never give up that easily :)
Plenum is now a R33 item, new R33 Plazmaman rail and shit fits now. Turbo housing back on too with a welded elbow, no more blowing off silicone hoses.
Not long to go!
  • Like 5
New dip stick, just because lol.
And these engine mounts, was going to get Nismo ones but Phil insisted I get these whilst he ordered a set for his S15. TBH I think they're gay as aids, drove his S15 and could feel engine vibrations through the steering column. But that's a stock bottom, unbalanced S15 so Yeah.
I have urethane mounts on the r34 and the vibration is pretty much unnoticeable after around 500km of driving. Same mounts on a friends evo 6 was a totally different story however.. these will be fine on the Skyline I think
On 31/12/2017 at 4:58 PM, NEO25T said:
How much movement or flex do those mounts have?
Are you going to put both in or just 1 on passenger side
They seem to have "some" flex, I'm skeptical. Run both for now, if they're shit I'm going to send it.... Into the bin.
Hopefully, the RB is somewhat more "balanced" than a tractor motor lol.
Hoping to get the motor in this weekend.
  • Like 1
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
