15 hours ago, niZmO_Man said:
Or buy a Tesla Model 3? :P
Lol...
Just because I have an investment property you straight away think I own a Lambo and snort coke off the dash daily (solid quote off OzBargain ???).
Nah haram car, creates more upstream pollution than a VW with the emissions defeat active lol.
I am too, but you gotta take one for a spin at some point, it is pretty amazing how bloody fast they accelerate.
Not very sporty handling and I can see a lot of inexperienced drivers getting into trouble  in these things
On 06/04/2020 at 8:07 AM, Jasoncauser said:
have you been for a spin in one?
one of the guys at work has a performance model 3
Damn is all I can say!!
No-one I know has one, then again look at my choice of friends ?
Looking back at some old photos, wow.. I actually had a white fridge.. then sold it, bought a mega clapped out Auto Salon bogan spec R33.
Was this one tasty?
1 hour ago, Count Grantleyish said:
Was this one tasty?
1998 S2 Unicorn, had Apexi Gameboy, and haram HKS2535.
Was a fun car, made 240kW, no creaking noises, no rattles, no rust, no bog, heck even the guards werent lipped or rolled.
Fast forward 10 years, current fridge rattles, covered in rust, guards rolled with a pole.. but doses like a boss and will produce instant cold sweat when you give it a hit.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
