15 hours ago, niZmO_Man said:
Or buy a Tesla Model 3? :P
Lol...
Just because I have an investment property you straight away think I own a Lambo and snort coke off the dash daily (solid quote off OzBargain ???).
Nah haram car, creates more upstream pollution than a VW with the emissions defeat active lol.
I am too, but you gotta take one for a spin at some point, it is pretty amazing how bloody fast they accelerate.
Not very sporty handling and I can see a lot of inexperienced drivers getting into trouble  in these things
On 06/04/2020 at 8:07 AM, Jasoncauser said:
have you been for a spin in one?
one of the guys at work has a performance model 3
Damn is all I can say!!
No-one I know has one, then again look at my choice of friends ?
Looking back at some old photos, wow.. I actually had a white fridge.. then sold it, bought a mega clapped out Auto Salon bogan spec R33.
Was this one tasty?
1 hour ago, Count Grantleyish said:
Was this one tasty?
1998 S2 Unicorn, had Apexi Gameboy, and haram HKS2535.
Was a fun car, made 240kW, no creaking noises, no rattles, no rust, no bog, heck even the guards werent lipped or rolled.
Fast forward 10 years, current fridge rattles, covered in rust, guards rolled with a pole.. but doses like a boss and will produce instant cold sweat when you give it a hit.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
