On 21/08/2022 at 9:54 AM, Dose Pipe Sutututu said:
There are plans for it, been a plan for a while lol.
I really should just do it, mainly for safety. Especially now I'll be easily doing 220 to 230km/h down the mainstraight at Wakefield Park (provided it even stays open now due to all the issues they're having).
https://autoaction.com.au/2022/08/19/wakefield-park-to-shut-the-gates-september-1st
  • Sad 3
On 22/08/2022 at 7:57 AM, admS15 said:
Here's hoping it's shut for a month or two and there's massive economic backlash everyone begs for it to reopen asap.
If not, there will be plenty of cheap houses, cheap commercial properties for sale very soon.
Let's be honest, there's not much to do in Goulburn
I'm still shocked it got this far.
Have been chatting with John Boston about (Track School) who's business is now basically on hold until something is done.
Yeah it sux big time.
I have done a few Trackschool days and they are awesome. Run very well.
Sad day for sure. Hope it does reopen, but I have heard rumours through a friend of a friend about a land development in the area. Hidden agendas etc.
I also hear from the same person that Pheasant Wood is planning on expanding its track to something like 3.6kms,with 2 big straights, which would make it bigger than Wakefield.
may also find a few cheap race car and trailer packages on the market if it stays shut
  • Like 1
  • Sad 1
It’s zoned residential so probably no industrial buildings
I was referring to the pubs/cafes/shop fronts etc. commercial properties up for sale soon when all the tenants vacant and landlords are forced to sell as they can't keep them.
I hope Wakefield doesn't shut.
  • Like 1
On 20/8/2022 at 5:25 PM, Dose Pipe Sutututu said:
BBQs Galore
Yeah I want to get a side exit extension for the screamer so I can roast marshmallows during antilag comps 😆. The yanks would lose their mind
  • Haha 1
2 Step Comp dis dat... funny it's not even "2-step", it's actually anti-lag with a secondary RPM limiter but hey it's cooler to just say "2-step".
Muricaaaaaaaaaaaaa fk yeah.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
