20 hours ago, Dose Pipe Sutututu said:
 Also got my cam trigger to sync quicker,l on crank, the arming voltage was too highPXL_20221015_102840698.thumb.jpg.f5dbd8e6f2089655b32d6f91ddec66c1.jpg
Waiting to fit one of these NZ cam triggers to the white 32. I see your post on the Haltech forum when you were having problems getting it to work. I take it the problem was they were sending the sensor out pinned to the cam signal instead of crank correct ?
16 hours ago, Piggaz said:
If you know it’s going to sit for a while, why not drain the e85 and run some 98 through it. A fitting off your fuel rail and some hose into a Jerry can.
It gets driven once a month lol...
Even if I drive it once a week, I still add in that additive. So far (past motors, setups, etc.) I've never had injectors gum up or seize, so it might work? (Or it's a scam and I'm donating money to the Lucas Oil execs)
It was initially pinned wrong by NZ Wiring then as I was troubleshooting, Haltech support advised to feed the reluctor 5V power, which is actually incorrect.
The reluctor actually generates it's own voltage.
I will confirm how I've wired it in a bit. Actually can't remember right now lol.
I got mine after @Dose Pipe Sutututu and had no issues with the pinning of it so may have a been an early issue or someone was a bit lazy that day.
Cheers for posting the arming voltage too as mine takes a few goes to fire on first crank. Fuel and timing haven't helped so will try this.
You use a link right ? The link you can reassign the cam signal cable to actually be the crank reference signal. On an Elite you can't as it is a fixed pin on the ECU, so they were sending them out preconfigured for link wiring on cas wiring pins 1 and 3.
Yes a reluctor generates its own voltage. Can't believe Haltech told you to supply it 5v !
From what I can see the neg reluctor side needs to be pinned to ground and the pos side signal output pinned to the Elite TRIGGER +, so on a cas loom that would be the 2 outside pins 1 and 4.
The way NZ wiring is sending them out appears that they are pinning the signal to the HOME + which will never work on an Elite unless you swap the pins at the ECU end which you don't need to do.
  • Like 1
Okay so some slight digging, you essentially pin it to GND and Trigger 1 (Link ECU reference). Trigger 2 is unused, I suspect that's the home signal.
Rb25Det Cas S1/s2 - Forced Induction Performance - SAU Community
12V is unused in this instance.
@robbo_rb180 got mine to start first go yesterday, but it does need a fair amount of cranking. I suspect it "might" want more fuel on crank.
I also went to town with the pulse prime, get those runners nice and moist when it's cold lol
Also tried adding more timing on crank, I think it makes it a bit harder to crank, will drop it all to 0s this week and try again
  • Like 1
5 minutes ago, BK said:
They way NZ wiring is sending them out appears that they are pinning the signal to the HOME + which will never work on an Elite unless you swap the pins at the ECU end which you don't need to do.
I'll go have a look and take a photo in a bit
That's the problem for the Haltech that they pin it to Trigger 1, which is actually your home + reference in physical wiring. This needs to be pinned to trigger 2 in the above diagram which is physically crank trigger position +.
I’m interested in this also..
just FYI, these are my wiring notes:
Elite 2500 wiring:
pin B1 = trigger + (black wire on sensor)
pin B5 = trigger - (white wire on sensor)
I also checked this with Scott from Haltech..
is this how you have it?
B5 Trigger - is not pinned from the rb Elite patch loom to the engine harness, but shouldn't matter as the ground wire on the cas loom is also a common signal ground which is also what the Link uses as its signal ground. The engine position should only need to be referenced onto B1 Trigger + so no ECU repining needs to be done.
Ah, sorry I am using one of their terminated harnesses. I checked continuity with multimeter back to the ECU pins to confirm they are connected
Elite 2500 wiring:
Just went to take a photo, I'm colour blind too so can't really tell what the 4th wire is, it's blue and something? LOL..
I'm using 1st wire as sensor GND and the 3rd wire (which is covered in heat shrink) as Trigger.
And yes, I should re-terminate that plug, I have a spare one to go on too - just forgotten about it.
in pic
Top - Black, then cream (white at some stage lol), then thick black, then bottom blue with green stripes (or green with blue stripes haha)
  • Haha 1
At least I’m not the only one they color blind, going to make it a nightmare wiring the engine up when the time comes lol
  • Haha 1
When I used to do quite a bit of wiring (when I was younger, didn't have back pain and had plenty of spare time) I would actually take photos and send it to my girlfriend at the time (wife now) and ask her what the colours were LOLOLOL.
  • Like 2
  • Haha 1
That’s basically my plan, every time I cant work it out I’ll get my mrs to tell me what it is
  • Haha 2
it's true we are hopeless without the missus!
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
