19 hours ago, Dose Pipe Sutututu said:
Just measured it, it's 134mm. OEM requirements is about 143mm.
Looks like might need the Dayco 115847 instead.
Fuarking.
well, FWIW that is the size that the GKtech adapter is designed for (134-143). I was going to say I have one for half price but looks like they are on sale for $19 atm anyway.
However, taking into account the feedback above on aftermarket couplings (I've got no experience with them, but surprised if they don't work out of the box) and I saw something about the Dayco coupling fouling on the GKTech adapter...it might be best just to go OEM
After all, we know you are keeping this car for 20 years and continuing to say how you want to sell it and buy the new BMW electric hover m2 instead.
  • Like 1
Thanks for the thought anyhow Duncan!
I will just return the fan clutch, I've already messaged the seller on eBay however no response.
Might just give it till about Tuesday and do an eBay return, then cry a little and order a brand new OEM unit.
3 hours ago, Piggaz said:
Sitting in the garage. More than welcome to see if it fits, was working fine only removed to suit dry sump setup.
Might take you up on the offer on the fan hub fits.
Will do Google tonight, intensely lol.
If not 2x options, both equally costly.
1. New OEM hub
2. FFG shroud and 16" Spal fan.
5 hours ago, BK said:
Don't think so, part is 21U082-05U00 and they're f**king $800+ now !
It's "nearly" the same 21082-75T02
Wonder what the real difference is
1. New OEM hub
Come get it and have a play. If it fits, great, if not return it or sell it for me. 🤣
Any chance you can measure the overall height from the hub to the top side of the fan?
I feel that they're nearly the same, perhaps different height (GT-R being probably shorter than the GTS-t one, however I'm running essentially a Koyo radiator for a GT-R).
50 minutes ago, Piggaz said:
Hmm mean from the top side of the fan blade to the base of the clutch, ie if you sat the fan flat on a surface, how high would be be overall.
100mm overall
95 for the height of the blades
I'll grab it, just measured mine and seems about the same height 98mm or so.
Considering the fan blade is identical and the water pump on either motor are the same it should be good.
I'm going to assume you want to get rid of the clutch and fan blade together?
3 minutes ago, admS15 said:
I'm happy to purchase a fan blade if there's one surplus. Mine has started to get little stress cracks and could do with replacement. Just saying😉
Sounds like we a threesome in a non homosexual way.
  • Haha 1
Yeah clutch and fan together. Fan blades would be lucky to be 5000 kms old.
PM me your number bro, you can't receive PMs for some reason lol.
Thanks again @Piggaz, shit box now has a working fan clutch/hub/coupler
Weirdly enough the RB25 one is higher than the RB25, so this means the fan blade is now even closer to the radiator shroud!
I have a out 6mm before the blades kiss the top flat part of the shroud. Might trim off that flat part if it causes any issues.
    • Ended up just being a loose exhaust bolt luckily.
    • Yeah I made that post way too early, sorry I must have assumed it was bad because it's a 20+ year old thrashed shitbox lol. It was just a loose exhaust bolt.
    • Like others have said, drop the power to give your drivetrain a % of reliability until you can up the drivetrain reliability  It isn't rocket science, build power to the weakest link with a % of safety Whilst upping the the reliability of the drive train is costly, there's no point in having the engine make big power if it keeps eating the drivetrain....ask me how I know, I had the tow truck on speed dial for a few years, and I spent huge amounts of money fixing issues and breakages that really would have been cheaper in the long run if I did it right the first time Me, I like a nice sized fudge factor, that keeps me off the tow truck
    • I don't understand what the issue is with, turn the boost down and start saving $$.  As soon as you can afford the supporting mods, turn the boost back up.  If the car is running fine, enjoy it. Turning the boost down isn't going to kill you.
    • That is surely the biggest gathering of Stageas in North America, ever!
