2 hours ago, MBS206 said:
It wasn't a pandemic in 2019 either. Someone said that statement, and how'd that turn out for us?! 😛
In beginning of March 2020 it was still a running joke, mid March it went to shit
Shit box survived all 7 sessions of hooning and circuit.
Didn't get a clean run on any of the sessions as there was a bit of traffic. Camber changes did make a massive difference and ended up going into T1 at 160km/h without the front washing out so happy with that!
Some eFame shots of the shit box.
348604191_1627263241111145_6932192459068028973_n2.thumb.jpg.6601db55192b3c2890b5bedefa7d1def.jpg
347620379_2212839058920237_4999811960215461977_n.thumb.jpg.f40e39d9f4b6dd97ec936f470c74bcf6.jpg
  • Like 5
Just now, ActionDan said:
Racing is all about WOTIF
Guess you better go race again ;)
haha next All Jap Day!
Meanwhile, I'm trying to work out what night I can go attack SMSP again, I am keen on a low 1m50s around the circuit with RS-4 tyres.
I feel that I am happy with how the car handles now, the front camber made a massive difference! Now it's just practice and more of it.
  • Like 3
I'm just glad to see you using the car.
I'm feeling slightly more motivated again, but wont get back to tub work until the XR5 engine is sealed to avoid contaminating it.
1 minute ago, Jasoncauser said:
Sweet, this is why you built it man! Go send it :)
I dont have headlights on the 32 so cant do the night runs :(
I suppose so, I also still hate the car. If someone walked up to me and asked for a straight swap with a M2/3 Comp I would do it in microseconds.
LOL... why aren't there headlights?
It's a bit like that, you see another working car and it gives you a bit more motivation. I did cheat and drop it off at a shop to do all the heavy lifting this time round.
Is that just a refresh on the XR5 OR full build?
The bucket I picked up for $500 with multiple spun bearings so I could try my hand at an engine build and teach the kids. It's just a stock refresh with some added block mod shims between the liners for if someone wants to lean on it harder later.
If it runs it'll cost me easy 5-6k in the end by the time I replace DMF/Clutch setup etc but could end up with a semi cool car to daily then swap/sell off for something else rinse/repeat as I'm sick of driving the 4wd daily.
It's manual, turbo, bucket seats, nice electrics etc and running is hopefully worth more than it cost me.
If it blows up on first start or I dont get it running, I will part it out, go back to Silvia and buy something else to daily (335i? 545i?).
Anyway, learning lots, I think?
  • Like 2
I should add, bad choice for a learning platform, FWD, 5cyl, Euro... not the easiest car to work on at all, it was like 10hrs to remove the entire front subframe with engine/box attached to get the engine out, I am dreading reinstall...
I really should have bought an XR6T or something, shit even an NA one.
  • Like 1
I
Funny story,
it was at the mechanics workshop sitting in the carpark and the drivers glass just fell off, he got it on his security camera lol. and the price of a replacement is just a joke, so we did this
@ActionDan well it is a Volvo afterall lolol
Hopefully home stretch to get it back on the road and dose city.
@Jasoncauser LOL how does a headlight just fall off lolol
Nope, I'm still mic'ing bearings because I "had to be sure" and double check the machine shops work.
That meant buying a mic and learning how to use it and associated tools lol
Oh then there was the 12hrs or so I spent weight matching the piston/rod assemblies because I "had to be sure" and weighed them all and found up to 8g difference....
Could've stopped at 3g like the machine shop said for a street engine, but "had to be sure" and went to 1g....
Shoot me.
  • Like 1
  • Haha 1
Because someone's been in there before you. They are a pain to pull apart from factory, no chance factory goop stopped gooping suddenly
Just now, Duncan said:
Because someone's been in there before you. They are a pain to pull apart from factory, no chance factory gooped stopped gooping suddenly
Yeah we thought the same when we looked at the glass channel lol
we did toy with the idea of putting lights in the panels we made but will just get those Motive headlight ducts down the track
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
