35 minutes ago, Murray_Calavera said:
What's the news?
The ic7 will be firmware updated to allow 2-way CAN communication allowing additional inputs for the ECU. It will also be a master device now, so I believe it can act as a controller for the PDM. You can also customise logos etc.
  • Like 2
Pretty much no need for an I/O expanded if you have a dash.
Also, there may be a new Haltech dash coming in the future, I hope they update the housing lol.
That's the only reason why I didn't buy an IC-7, I know it's silly, sure it's ugly but the car itself is pretty ugly too LOL.
Yeah, I think they are bringing out a bigger display. I think a 10”??
the ability to programme the buttons on the display is pretty good too.
One can hope, if not I'll just get an IC-7 and stop sooking.
Loaded up the latest firmware, oh wow... went for a drive and it's like I've setup Alpha-N and MAP compensation. I thought the transient table I built was good, but wow... this just brought it to another level.
@R3N3 this is how I make the car brap lol.. sounds better than rotational idle
Nice little timing hole lol
And for the idle control you want it to not much between -50 ~ -100 RPM
Awesome! I will compare the sound. I ended up dialling in the launch and rotational idle 100% many bangs and flames were had. Although I’m a little worried about my stock oil pump gears…
  • Haha 1
1 minute ago, Dose Pipe Sutututu said:
Didn't you want to build a new motor? LOL.
Haha, true! The plan is to switch out a working motor with another working and better motor…
Last time @admS15 used his launch control, he lost a turbine LOL.
On 08/10/2023 at 1:38 PM, Dose Pipe Sutututu said:
Washed the shit box, forth wash since the start of 2021 when the respray was done.
As much as you like to complain about it, your car is a looker! Is this photo with new tints? Which ones did you end up going with?
It's on my list of things to do, though not at the top. Being able to see nothing at all out of the windows when it's dark and wet outside gets old very quickly.
I work in IT, complaining is a prerequisite LOL.
I went with a legal 35% tint, it's some ceramic bullshit (apparently good?). Got it done by Tint a Car in Moorebank.
  • Like 1
Haha, fair enough. Yeah ceramic is meant to be better with keeping off heat. Or so I learned doing all of five minutes of research.
But for some reason the extra photos you included in your post that show the new tint don't load.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
