On 12/27/2016 at 4:53 PM, dyl33 said:
Never made a snowman :( been sunburnt though.
Civic sounds like the better car,  1. It still drives with 372,000km  2. It doubles as a snowmobile what more do you want.
It has been a very reliable car to say the least, still on the original clutch!  Just had to use the snow blower to clear out another foot of snow this weekend:mellow:
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7802106
  • 1 month later...
Yeah, heat is good, I don't mind the dry heat, good swimming weather.....but the humidity this year has been hard to put up with.  If I wanted humidity I would live up north ffs.
And you can stick your snow [sorry Josh]....I live near it [aussie style] and hate the stuff, PITA.
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7811513
  • 10 months later...
I guess on the bright side, every Spring thaw must be like Christmas since you get to pull the wrapper off the GTR again. Driving the Civic would be like a reset button on your concept of a quick car.
You could always pick up a G35X for some quick(ish), cheap(?) Winter thrills.
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7863951
I used to drive a modded Subaru Outback turbo for a daily but now I drive over 1000km a week so I got myself the hand me down civic from my father when he bought a new one but then I got tired of fueling up twice a week so I bought a beat up tdi Jetta wagon that's coming up on 500k km but goes almost 1200km a tank. Now its to damn cold to work on the gtr, the engine needs to come out to get the shortblock rebuilt with some forged bits and new bearings. Then after that's all done I have a pair of -5 turbos and all the supporting bits to go on.
https://www.sau.com.au/forums/topic/468327-withdrawl/#findComment-7864235
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
