Hey guys, im about have a go at the fuel pump relay rewire mod.
I just had a few basic beginner questions, ive had a search but couldnt find anything.
1. The blue wire is the active and the grey is the ground? Is this correct?
2. The blue wire has been cut and joined to purple wires going down towards the right of the back seats. Any idea why this would have been done or what its for?
Thanks guys
20161231_200020.thumb.jpeg.0cc01da34a58d
The ground wire will have 0v potential between the wire and the chassis, and also 0 ohms resistance between the wire and chassis.
Actually, a cheapo meter wont be good enough to measure a few ohms or less, but it would be worth checking how much resistance the ground wire has. ie, there may be a couple of ohms in the worst case. No guarantees on the quality of the wire splicing by the looks of things.
The only hassle is that the ground wire is the switched side.  So if everything is off, there will be 12V on the supply wire and on the earth wire.  When the ECU turns on the fuel pump, the relay on the earth wire side will close and go to earth.  As a first step it's easiest to pull the wiring connector off the pump wiring and simply probe the two wires to find which one has 12V.  In the absence of a local plug, you could simply cut all those wires at their joins and work out what's what then put it back together with uprated wiring, pump, etc.
The fuel pressure controller also gets involved in what you measure on the earth side.
Thanks for the help everyone. I ended up finding the grey wire was the ground.
So for a r33 gtst s2 (at least mine anyways) the active is the light blue wire and the ground is the grey wire.
I did the fuel pump relay mod with the help of the guides on this forum and some other sources online. I know this is piss easy for some but i have no idea when it comes to wiring and such so it was confusing, but it finally clicked and i enjoyed putting it all together.
Turned the key with fingers crossed and immediately noticed the fuel pump priming was louder. Car started perfectly. Going to neatly tuck away wiring tomorrow and check voltage.
Thanks again guys
I was working on the car today and i notice that the car idles rougher at idle with the fuel pump relay mod than with the standard wiring. I measured the voltage with the relay mod and it was 14.2v
Normal wiring is 13.75v
Can the fuel pump relay mod cause rougher idle, im pretty sure ive done it correctly?
Don't suppose you have an AFR gauge? It may be just enough extra fuel pressure to richen the tune up a little which may have just been enough. Usually I wouldnt think it would be enough to throw out the idle (would have thought so if going leaner) but I'd say that would be your problem. If you have a hand controller, go to the menu that lets you add/take timing and fuel over the whole map (can't remember what it is called, in settings 'inj/ign something' i think) and slowly take some fuel out while it is idling. If this doesnt work then try adding some fuel. See what happens. At idle theres not a great deal of damage you can do
  • Like 1
Thanks for this, nahh i dont have an afr guage. Disconnected all the wiring from the relay and reconnected. It seems to be running better, im just gonna leave it as is and let the tuner sort it out when i take it it.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
