Pre production nismo er34
Rare pre production Er34-000131.Built 5/98,
1 of 5 ev1 yellow cars in the pre production run of 30, feature car used for nismo fr street parts catalogue, Can be found in Gtr-registry.com. Owned by 32yo mature enthusiast.
Car was exported on the 10/06 with 83400km, currently sitting on 92xxx.
All export documents, Dereg and shaken reports available along with owners manuals, dealer brochure/price list and Nismo catalogue/ paper work found under the rear seat.
Car spent some time at nismo paddock/omori, has the catalogue less rear wing fitted.
Nismo r tune coil overs
Nismo sway bars
Nismo lmgt2 18x9 with centre caps, new 265/35 semi slicks
Nismo s tune front bumper
Nismo 2 way gt LSD
Nismo super single clutch
Nismo slave cylinder
Nismo triple gauges
Nismo dash cluster
Nismo s tune stripe kit
Nismo gt led tail lights
Nismo smoked bumper indicators
Nismo smoked guard indicators
Nismo r32 n1 boot lip ( not fitted,but painted ready to go on)
Moonface/superlap jp tension rods
Moonface/superlap jp roll centre adjusters
Moonface/superlap jp rack ends
R34 Gtr 10 point under body brace
R34 Gtr front seats
R34 Gtr v2 aluminium pedals
Superior auto carbon gear/radio surround
C's short shifter
Car has been in storage for the last year and has had a lot of preventative maintenance done and new oem parts fitted. I intentionally made the engine setup look factory, whilst waking it up. All standard parts are also available with sale.
Hks3037pro s turbo, .86 rear
4" stainless intake, z32 afm, apexi power filter
Hpi low mount 304 manifold
Turbosmart 48mm progate with 316 screamer.
3.5" dump pipe, 3.5" hks SuperDragger with jasma step down removed from rear can.
Apexi delta fin intercooler
48mm ally rad, nismo thermostat
R35 Gtr 570cc oem denso injectors
Twin Walbro gs342 in tank pumps
Power fc with add on boost control kit.split fire coil packs
New oem belts fitted.
Motor was rebuilt by previous owner, has Ross 86.5 forged Pistons, cometic head gasket, arp head studs, new bearings/oil pump/waterpump/gasket kit.
Car was tuned by dvs Jez in October, Comptest/leakdown/smoke test inlet, on gate pressure, 18psi with no timing in it, comfortably made 270rwkw @ 85 percent duty cycle on 98oct, fuel being the limiting factor.350rwkw is there for the taking with a set of 1250cc injectors and an e85 tune.
Car was pulled down/inspected and resprayed in fresh ev1 by medicar, campelltown, no accident damage or rust was found.chassis rails are straight and not crushed from incorrect jacking like most, factory under seal still in place (no cover ups) Car was painted inside and out with the exception of the engine bay and underbody.Car was completely cavity waxed to ensure its survival for the next 20 years.This was not your typical cheap respray that are the flavour of the week.new oem weather trims were fitted.
New xenon headlight housings were also fitted.
Car has been ceramic coated with opti coat including glass.
all electrics work as they should, climate control works as it should,
stereo is a basic Sony cd player and alpine type s 6" speakers front and rear.
Will not find a cleaner Gtt unless Nissan Japan has one tucked away.With the prices of 34gtr's skyrocketing and Gtt's slowly climbing in price as they're being exported to Canada/China/USA, this represents a great investment and bang for buck. Currently insured with NRMA vvc for 25k, awaiting an increase in cover, after appraisal.
Car is currently unregistered/in storage in a climate controlled garage as I have no intention of putting kms on it, can arrange rego for buyer.Can also accommodate a permit to drive for interstate purchaser or interstate freight.High res/detailed photos upon request.
Car will only be pulled from storage once proof of funds are made available.
Mechanic / specialist inspection welcomed under my supervision.
Firm on price, plenty of wound back r-grade cars available for less.
Only selling so I can free up space to work on my Gtr.
Please do your research before contacting me, as to what this car represents and ONLY contact me, if you're a serious buyer.
i am not interested in swaps
located south of Sydney,nsw
Car can also be found on carsales
0410252456
[email protected]
Thanks, Tim
https://www.sau.com.au/forums/topic/468406-pre-production-nismo-er34/
Short 1-3 pull video on the highway on the way home from jez's, the 3037 sounds like a baby t51r before the gate opens, makes full boost by 3500rpm. Very fun car to drive
IMG_6051.MOV
IMG_6053.MOV
IMG_6051.MOV
IMG_6053.MOV
What were the vids about , hard to see anything except the dash :(
Need something different :)
Only have these 2 videos of the drive home from Jez's on my phone. They were more so recorded as I was impressed with the sound and tone of the 316 screamer I made/wanted to share it with my friends at the time
Jez does a good work, I like the yellow ,  I have not seen one before. Do not mind the work on the side and I do not usually like that type of thing :)
5 minutes ago, Livinlahtimmah said:
They're nismo s tune stripes, extremely hard to find decent fitting items as the originals are no longer produced. Mr fijigold helped me procure the set :)
They blend in nicely with the cars profile
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
