Bringing a GTT back to glory
Hey guys, this is a current work in progress
let me flood you with the details
Pictured, how i bought this car 2 years ago, paints f**ked, gt wing, crystal tailights.
my reason for even looking at this car was of how early it was imported.
having a compliance date in 2002 and being a 1998 model i knew rust would be minimal, after inspection i was right, not a spec anywhere!
chassis rails unmarked aswell, factory manual turbo,
Those f**king tailights, (shudders)
Since the motor was healthy besides a stuffed IACV, i fixed that and got straight to the cosmetics.
new oem lights sorted,
Some Miesters 18x9 +30 and 18x10 +30
i had ready for the car and an east bear front lip i scored from a wrecker who was unaware what it was!
At least now it was starting to look less like it was ready to go the tip.
From what i could tell, the car was never polished or cleaned, after days on days of Clay bar, buffing and waxing
majority of the car came up great
- Mirrors had to be painted
- drivers rear skirt has to be painted
- front and rear bumper needed resprays
- boot lid had been warped from the gt wing
- driver door has a big bend from being opened against a pole
All pic's after paint repairs and detailing
from here i moved onto some interior bits
led light conversion to white, also have done air con controls to match, and im assuming the original cabin filter. has been replaced straight away
old butchered wiring, then my fitted pioneer double din, From here i moved onto my custom flush gauge install
factory gauges, with then without factory cover, then seperated
then the aftermarket Shadow gauges, Split the lense and bezels
the aftermarket gauges basically pressure fit in to the factory housing, i really dig the look without the bezel
After the gauges were mounted, i tapped into power, acc and earth from the original harness, ordered a brand new clear face from nissan
and here you have the finished result! Also, had the gauge surround, air con and vent painted satin black. very easy to keep clean!
Back to the outside, trying to find a body kit that doesn't look cheap or ruin the car was quite hard, eventually i decided on the east bear rear bumper
all i can say is east bear is worth the money, 100% perfect fit, no modding needed and very strong fibreglass, so happy with the purchase
This is factory
East bear fitted without pods, also note late model nissan badge!
with rear pods
thats all for my first post, more updates very soon :)
Edited by stump_69
  • Like 5
https://www.sau.com.au/forums/topic/468815-bringing-a-gtt-back-to-glory/
I actually really like what you've done here. Such a nice stealthy factory look.
Looking forward for more updates. Certainly looks like you have a nice 34 in your hands.
  • Like 1
On 1/27/2017 at 6:51 AM, Brett Musolino said:
I'm currently in the process of changing my gauges, looks like I'll have to do all three at once
Definitely would do all three together!
12 hours ago, GH05T said:
good work.
how did the paint hold to the plastic. that r34 soft plastic shit is a nightmare once it starts to go bad.
sacrifice some rags and use thinners, comes off very easily.
then primed and painted off the gun, so easy to take care off now
8 hours ago, Jordy32 said:
Looks great, did you get the rear bumper from japan?
 Yeah all the east bear products i have, besides the front lip have been from Rhd japan
not cheap, takes ages to get here. but absolutely perfect fit and finish
  • Like 1
Next up!
More GTR influence, got a factory foglight from nissan, wired into tidy hidden switch
Wired up some Leds to work like gtr valet lights
Some color coded v spec extensions, screwed straight to factory skirts
A gtr rep wing was next, i sourced a factory blade, but im still not happy with the finish
will be getting a genuine one in the future
All painted!
Cosmetics coming along nicely :)
still more to come!
And some nice interior finishers
Gtr Gauge Bezel, was annoyed i couldnt make a gtr cluster work :(
Brand new center trims, leather boot and cig lighter from jesse streeter, hes the way to go for new nissan items!
And a brand new oem gear knob
More to come!
Edited by stump_69
  • Like 4
Next up!
All painted!
Cosmetics coming along nicely [emoji4]
still more to come!
Gtr Gauge Bezel, was annoyed i couldnt make a gtr cluster work [emoji20]
More to come!
Hey mate awsome car looking really really nice good on ya. Keep the updates comming.
47 minutes ago, Brett Musolino said:
Loving this thread! The lip you put on your stock front bar, is it just from eBay? And was there much adjusting to do to make it fit?
Its from rhd japan
Its a east bear front lip
  • Like 1
  • 1 month later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
