xanavi.ru
Xanavi.ru seem to have available kits for Japanese to English conversions (including Australian, but not New Zealand, maps). Pricing seems ok - I am just wondering if anyone had any particular cautionary tales to tell in terms of them taking money and not dispatching, or sending the wrong things? I'm more than happy that I have the skills to remove and replace the unit - more concerned with whether or not I can trust the Estonian company.
Thoughts?
Cheers - Neil G
https://www.sau.com.au/forums/topic/468847-xanaviru/
You need an installer to do it as far as I am aware. Each state of Aus had a guy that did it, and part of the process was him calling Russia/Estonia real time and them decoding a code that the car ECU output based on time and GPS coordinates - definitely did not seem to be something that you could do (or they would let you do) yourself. Things might have changed though.
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7807863
Oh cool. Do you have a link/info? This might sway my decision to get a V36. I had been leaning toward buying an ADM Infiniti G37 due to the language limitations of the Jp system, but the price premium for them over the V36 is insane.
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7807865
Heh - look at my first post. I am wondering if I can trust them. I would hate anything I say to be seen as the start of a circular web of trust. Someone I don't know put me onto them and I am trying to get some due diligence done. Their website has the info but you have to autotranslate and do a bit of digging.
Cheers - N
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7807866
Cheers - N
Do you have a price that you can share with us?
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7807871
Definittely changed... This particular option is to get sent a new head unit, already setup for English...
Oh? What about programming the BCM to accept the new headunit? If my memory serves me well, that's part of the process in the USDM workshop manual.
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7807877
Ohhhh, I just got another email from them and it's a bit clearer now and no-where near as good a deal as I thought. $790+$50 USD shipping. They send you a replacement main unit and you have to send them your unit. So it's $800 USD for their software still. Aaargh. [Edit - I read their email again - English is not their first language - but I know none of theirs! - it looks like they will give a credit for returning the unit you remove. Obviously that's how they get their stock of parts to flash the English onto. Maybe it's not such a bad deal. I have asked about the credit amount.]
Don't know about the BCM programming...
Cheers - N
Edited by talkiet
  • Like 1
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7807910
I had a look at the website and cant find anything your saying.
I have been installing the software for over 5yrs and have never heard of what your talking about.
Maybe its to cater for english speaking countries other than ourselves that dont have installers.
That price you quoted was fairly high for an english conversion.
Does it have anything to do with an australian map disk maybe.
Also i dont think there are many installers left in Australia apart from me.
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7808088
Cheers - N
That's a bargain.
you'll be without a unit for a time but if that's not a problem...
I paid a lot more than that for Oz maps and English for my V36
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7808295
17 hours ago, colin.ssc said:
High for english conversion? how much do you charge for 07 V36 Sedan conversion then? The last 2 people in Australia that I spoke to wanted $3k for supply and install.
For some reason I thought we were talking about the v35 and getting maps. Its probably cheap then.
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7808296
Actually, I'm not going to go ahead... Being charged over $1000NZD for a pirated software upgrade is just something I can't in good conscience be part of. I'll continue struggling with the Japanese. MAYBE if it gave me navigation as well I could swallow my pride but just for an English translation? A pirated one? Nah...
Cheers - N
https://www.sau.com.au/forums/topic/468847-xanaviru/#findComment-7808313
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
