HKS EDA&ETC + NISMO Old Logo stuff
BNR32 HKS EDA and ETC $950 USD
Black Horn Button $190 USD
Green/Silver Button $130 USD
BNR32 Nismo 320km/h R32 $450 USD (late model)
BNR32 Nismo 260km/h R32 $300 USD (late model)
Shipping is around 20/30 USD and paypal 4%, Any questions are welcome and I will answer then gladly. I'm located in Amsterdam for reference, but shipping isn't a problem.
Edited by StefanjR33
  • Like 1
4 hours ago, Birds said:
I miss Amsterdam :(
I was there for a total of 6 months for work. Smoked a joint once and didn't get high :(
Although I did have a space muffin, was fun trying to sleep.
  • Like 1
3 hours ago, StefanjR33 said:
Haha, you wouldn't miss it if you ever tried driving a Skyline in Amsterdam with all the monster speedbumps we have :(
Fun for the bicycles though!
In the ten days I spent there, I only saw one WRX. Good to know there are Skylines around!
Holland is full of them, but only a few in Amsterdam. Its a city that does everything to make you hate owning a performance car!
Cobblestone roads everywhere, bike lanes... fun times.
I only saw one modded 5-series BMW from the early 90's, every other car was a commuter car.
  • Like 1
Perfect discription, now its even worse goverment subsidies have made it a town overrun by Tesla's! Damn i hate those things.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
