Front/Dump Pipe/Exhaust Help
Hi guys.
I want to upgrade my stock dump/front pipes and cat on my R34 GTT. I don't wanna go overboard. It's just a daily driven car. Right now I have a SR JASMA cat back exhaust. I think it's 3", but I am going to replace it with a Blitz Nur Spec cat back later on.
Firstly, I would like to replace the front/dump pipe. I saw this on just jap:
http://justjap.com/jjr-stainless-3-bellmouth-front-dump-pipe-nissan-skyline-er34.html
JJR Stainless 3" Bellmouth front/dump pipe
And this cat:
http://justjap.com/x-force-3-stainless-high-flow-cat-nissan-type-3.html
X-Force 3" Stainless High Flow Cat
Question 1: Would these two pieces bolt up together? i.e would the flanges mate up perfectly? Or would I have to modify them?
Question 2: When you put the pieces together, do you have to use some special silicon between the gaskets? or do you just use the gaskets they provide?
Question 3: Is it very important that you need a tune after the installation, or can i just adjust my boost controller down a notch and all is well?
Question 4: Would it be a good idea to wrap the front/dump pipe in Titanium wrap or waste of $$ and time?
Question 5: What is the cell rating on that x-force 3' cat and is it a good buy for a daily driver expecting a little more power gain (with supporting mods in future ofcourse)?
R34 GTT Coupe Manual
RB25Det, stock turbo, FMIC, stock ecu, boost controller,
https://www.sau.com.au/forums/topic/470030-frontdump-pipeexhaust-help/
The dump is a fine basic choice.  The cat should bolt to it no problem.  Both of these parts are intended to swap in for stock pieces with other stock pieces or with other stock-swappable pieces.  Just use the gaskets.
The cat is just a ceramic substrate, so it won't be particularly excellent in the flow stakes.  Couldn't tell you how many cpi it is.  Doesn't matter, wouldn't buy it in preference to a 5" Venom metal cat with 100 or 200 cpi.
Wrapping the dump will keep the engine bay cooler, but likely shorten the life of the dump.  Your choice.
You won't need to adjust your boost controller unless you pick up noticeable extra boost.  R34s aren't good with more than ~10 psi on the stock ECU.  As for the tune question, if you are running as much as 10 psi, you will benefit from tuning it already.  But as he^ said, you can't unless you minimally put a Nistune into it.
What cat would you guys recommend? Are Venom really good ones? I saw this on their ebay store:
http://www.ebay.com.au/itm/3-Nissan-Skyline-R34-GTT-VENOM-High-Flow-Cat-/251254455756?hash=item3a7feebdcc
Can't find a 5" one but would this 3" Venom be better than x-force?
I'm thinking of purchasing this cat back system:
http://justjap.com/blitz-nur-spec-r-exhaust-system-nissan-skyline-er34-2-door.html
Any thoughts on this?
I heard they are awfully loud. Not really keen for angry looks or neighbours but oh wellz. What do you guys reckon? Good buy?
Edited by RB25Detonator
I've heard they are quite loud also.
I went with the HKS silent hi power which isn't too loud or droney as it has a mid muffler, not just a resonator.
There's also the full custom system option which can be made however you like
My only advice is to steer clear of the JJR systems, I installed one for a friend on the weekend and it required an angle grinder and a welder to make it fit properly..
You get what you pay for :)
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
