Old school Omori mechanical boost gauge
Old school omori boost gauge
Includes original plugs/wiring and a little bit of vacuum line.
Thomastown Victoria
$130ono
Freight available to business addresses only.
(Sick of paying postage fees when TNT has to redeliver)
MESSAGE ME ON 0411-421-097
I AM NOT ALWAYS ON HERE SO WILL DEFINATELY MISS AN INBOX MESSAGE.
Assorted r32 parts- air con, complete front cradle, c34 stagea tein coilovers
Okay have accumulated a fair bit of random "should be easy but kind of hard" to get parts which  need to sell and free up some space.
R32-
complete GTST interior dash loom, including interior fuse box. $180ono
Complete steering column assembly, telescopic and height adjustable. $100
R32 sedan centre c pillar trims (the ones between the doors) $50
sedan door seam rubber covers $50
original R32 side mount intercooler, including shroud and mounting brackets  $100
original R32 GTST/4 airbox SNORKEL, not the funnel looking thing, but the bit that is beyond that going into the bar. $70
Complete GTS4 engine subframe and associated arms, includes knuckles, drive shafts, steering rack, some power steering lines.     The subframe does have some rust, which is an easy fix. Arms will need new bushes. $200ono
r32 sedan boot lid, one corner is bent. Easy fix. Includes the lock. $50
GTS4/GTR alloy rear knuckles $80ono
complete R32 skyline air conditioning set up. Including bracket, compressor, condensor and associated lines. $600
RB26 power steering pump $100
gts4 early model dash cluster $70
STAGEA
Tein super street coilovers to suit C34 stagea. Good condition, only selling as id want some standard suspension for it.$700ono
other
omori mechanical boost gauge, includes original plugs and wiring. $120 ono
all items located in Lalor Victoria, freight is available, buyer organising it is preferred. Happy to package it for you.
please message me on 0411421097
On 04/05/2017 at 11:00 AM, iruvyouskyrine said:
What size is the omori mate?
hey mate, 52mm face
On 07/05/2017 at 7:55 PM, misko said:
do you have the stereo surround?
no.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
