Any previous experience with eboost mods?
Hi Guys,
Just looking for some ideas on what could be causing an issue with my boost system.
I've just had my R33 tuned and we have basically rebuilt the entire engine from scratch. There's mechanically no reason why this car shouldn't run 1000hp or more happily (as far as I know).
However, I keep maxing out at approx 500hp. Boost system is creating the boost, but isn't actually using it as far as I can tell. I know it's going to be something really simple, but i'm stumped.
Any suggestions?
Cheers!
Boost system is a pretty wierd way to describe a turbo. Assuming it is a turbo, what size is it?
What is do you mean the boost system is creating boost bit not using it? No way would an na 2.5 make 500hp so boost is being used.
If you didn't spend more than $10,000 you won't be making 1000hp.
have a look through your receipts and list the main points - turbo, injectors, cams and if possible put up such dyno charts as you might have - torque, power,  afrs, boost  - are those most commonly supplied.
BTW if you are making 500hp at the rear wheels your car should be pretty fast!
 Share
