Anyway of comparing torque figures from 2 different dynos?
See attached images. Old graph (Dyno Dynamics), with higher power and lower torque was done 3-4yrs ago using SAFC and SITC.
The only change, new graph on Mainlne, was a Nistune, so I could have some proper off boost/part throttle behaviour and smooth out that torque dip (through controlling the inlet butterflies properly).
Is there any way to compare the very different torque readings wit the info at hand?
Just back calculate a torque number from the power using the normal formula.  It won't be numerically correct, but because it comes from the only thing that actually matters (power at the roller) at least you're starting from the same basis* and can draw graphs to compare.
*of course, excepting the different dynos, operators, tyres, years in between, etc etc etc.
I have torque numbers from both dynos. They are very different (360Nm vs 550 or so).
I know power is just a function of torque vs revs, but given these dynos do various corrections to get their numbers, I have no idea how to apply anything to either number to find something meaningful between them.
It's because the operator on the Mainline didn't use an inductive pickup OR setup the derived RPM via syncing RPM.
Once that is enabled you can select show 'Derived Torque'
/Thread
Even when plugging figures into calculators with known RPM, the output is not like either graph.
All smoke and mirrors.
Oh well, see how it goes Sunday and will just hope that a smoother graph means a better car to drive (yes i know graphs can be smoothed also).
Also the power diffence is sfa when considering its 2 differnt dynos on 2 different days, I'd love to see the boost plot from the dd run as a tiny overboost would explain the hump around 4g on the dd graph
Also the 550nm mainline number in this case would definitely be the bs number as with out a rpm trace there's no way it can give torque reading with reference to the engine
  • Like 1
If you are not measuring the same car on the same dyno on the same day a good way of telling the improvement is to compare say 80 to 120 km/hr times - too late for you now of course. Does the car feel better to drive now?
Boom! Someone that knows :)
Quick report from track day.
Car felt gutless, no surge of torque when it comes on boost. Also a little bit pinging somewhere up in 3rd, was not logging so cannot tell. Had a few misses/hesitation when cornering (car has surge tank setup) though tuner did note fuel pressure was fluctuating quite a bit with temperature.
Despite the car feeling gutless and less powerful than I remember it (a few years ago) the max top speed down the straight was identical and the lap time was within 1 tenth of the previous PB 0_0
Given the max top speed was the same, I'd say so.
Though I need my old phone to look at the Race Chrono data and see if the corner exit speed onto the straight is the same to be sure.
Not after seeing GT-Rs "economy" on e85 and the fact I can't get it here. Annoying enough bringing back 80L at ta time for the GTR (which ate 140L at winton...)
Silvia wouldn't be as bad, but still. That means injectors and a full retune on e85, or additional e-flex sensor then really should go to proper boost control etc etc.
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
