Wrecked R34 GTT HTA3076 twin scroll rebuilt gearbox E85 fuel setup
R34 GTT wreck
Car has a lot of great parts on it with very low klms
HTA3076 with Sinco twin scroll manifold and two turbosmart external gates along with screamer pipes and dump - fitted may 2016 (Amazing turbo, Total cost $5000+ Had to buy the turbo then get the twin scroll housing separately from GCG then get screamer pipes and dump made up)
rebuilt rb25 gearbox (have receipt for $3800 from last year - very low klms)
Big fuel set up - ID1600cc injectors, 1000hp external fuel pump, surge tank - all suited for E85 (Injectors were $1200 by themselves)
power fc
ARP head stud kit, Nitto head gasket, Tomei type B cams, performance valve spings - fitted august 2016
Greddy radiator
Wilwood big front brakes (I believe around 350mm? - require an 18" wheel minimum)
RB25 Neo internally standard
Those are the parts I can think of right now.
My preference is to sell the whole car as is. This is due to the fact that I fractured my humerus in the crash, otherwise I would part it out. If I cannot sell it whole, I will store the car for a while until my arm gets better and take all the parts off and sell them separately.
Asking $8000 which I think is a pretty good deal when you consider just the cost of the turbo kit and gearbox were actually higher than this by themselves.
Edited by vkadam
  • Like 1
On 13/06/2017 at 6:56 PM, ERO54N said:
Fk dood, you ok?
Yea not too bad Thanks
On 13/06/2017 at 9:15 PM, Anonymouse said:
banged up good - car and you
Want to tell us what happened?
Impound yard?
Not impounded just at the crash investigation centre.
On 15/06/2017 at 0:51 PM, B-rice said:
I live in Canberra and interested in some parts. Provided if you allow me to remove myself
Which parts are you interested in? I was trying to sell the wreck whole, however the bigger the item and the more $$$ I can recoup, the more I would be interested in separating parts out.
 Share
    • I've got 60L of e85 in there at the moment
    • Don't forget to make sure the tank is full to the brim before you try to replace the fuel pump too, that is an essential step.
    • No, 260RS/4wd stagea is 33 GTR/GTS4 double wishbone all round, not struts. The 2wd cars are confusingly strut front. At there rear there is one balljoint at the outer end of the lower control arm. If you have HICAS (my Stagea doesn't, but I think 260RS did, there will be a balljoint of sorts where the HICAS arm attaches to the rear of the hub At the front, there are ball joints either end of the lower control arm, plus the tie rod end for the steering arm
    • So, 2 months later, I just couldn't see any way to be happy with that tank setup. Basically the baffle area is too big and too leaky, the sender was miles off and the no low fuel light thing really bugs me. Other than the fact the fuel hat could safely supply enough power to the pump, it was worse than factory. Biggest thing that bugged me is it would still run out of fuel in medium-high g corners from about 1/4 tank down which is annoying when you are trying to have a zoom, not to mention potentially engine killing if it gets just the right amount of lean-ness....and we've got a few of those corners in our round trip to town (well, bunnings...) So, credit to Frenchy's, they have put together a much better designed setup with what is effectively an in tank surge setup.   As it happens the actual hat is the same, so I switched the fittings across, re-used the single 525 pump, and added a spare pierburg lift pump that I had (must remember to replace that stock, it was a spare for the race car). The only real work to get it all done was to add a second power and earth to the hat which I did by going from a single output to double output relay (very low draw on the lift pump) and also the sender unit that clips into the factory pump holder was again way too loose (so I re-used the 2mm shims from the previous setup). Finally, I added the low fuel light sender from the factory cradle. So....I'll report back how it handles low fuel, and if the sender has any relation to actual fuel level in the tank....
    • The price isn't the issue, it's how hard my fuel pump is to remove now. I fabricated a custom bracket so my pump sits on the very bottom of the tank (I ran the tank down to 5L remaining to test it, works well). But it is a fkn NIGHTMARE to get the pump down into the tank now =/ words can't describe how much I hate fighting with the fuel pump/hanger now. The other issue is reliability, I'm driving down for WTA in a couple of months, I'd be less then impressed if I was half way to Sydney from Brisbane and my pump fails again =/ The other issue I had was my car battery was slowly failing, with low battery voltage my fuel pump couldn't keep up with what the reg was asking from it. I've replaced the battery and my fuel pressure is back to being perfect.  As for the low voltage situation that killed my previous battery, I've got a 150amp alternator sitting on my desk waiting to go in. Fingers crossed that will sort that issue.
