I was looking for something else on Google images and saw them pop up which led me to them.
I have bought a fair bit of stuff off Aliexpress like titanium bolts and step drills, and they are well up to the task for the price.
Engineered parts though, I'm still a bit skeptical about
Just stick the same factory that 50% of brake brands use for big brake kits out of Taiwan.
Cost price is like $700-900USD for a pair plus shipping for 4-6pots including pads/rotors/lines. Its just that most brands put decent mark-up on it. You can get them without a brand on the side of them, I dont know how you could get a set off them though...
Source: I got sponsored a set and it included cost-price invoicing.
Seems like every Japanese 'tuning' company has their own brake kits (looks the same as the ATTKD/D2 ones).
Those are the ones out of Taiwan. 326 Power, every VIP company in Japan, all the US instagram companies operating oout of someones loungeroom, etc
  • Like 1
So you have been the guinea pig by the sounds of it :19_kissing: Which "non-brand brakes" did you get and what was the quality like?
Feel free to correct me if I'm wrong, but when components are manufactured in China for a big company and the patent runs out, I'm sure that the manufacturing company is free to manufacture those designs from then on without approval? EG, all the carbon frames that the likes of Giant and Specialized get manufactured over there all have identical charbon copies. I know that one big hub company that has $200+ hubs is made under the same roof as the $70 Novatec hubs, only the brand name constitutes massive price hike and QC is not as stringent.
  • Like 1
My friend started selling brakes with his own business on them "Diamond Brake Design". I haven't really pushed them yet, but I was impressed at how straight-forward installation was. Everything in the kit was spot-on.
When we both saw top cars at WTAC and Aus/NZ Endurance racing use brakes from the same factory, so they do a pretty stellar job for amateur and semi-professional requirements. Obviously if someone was super serious about the setup you would source your own rotors and pads and probably have you're own brake lines too. So the kit would be just for the calipers and mounting bracket.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
