On 01/09/2017 at 9:45 PM, fatz said:
Over the period of 10 years I have got about 20 slabs and had my trailer rebuilt 3 times by people borrowing it
dont lend trailers
This!
Since buying a new trailer I've never loaned it out and have no intention to. Previous trailer was damaged each time someone borrowed it. People have no respect for others' property.
I hear this alot. I guess it depends who you lend it to.
A mate bought himself a newish trailer recently and is very selective about who uses it.
If he doesn't like their style he just says no, simple as that.
  • 2 months later...
A decent tilt trailer is 3-5k.
Borrowing the neighbors costs me $40-50. At the local track here's a spot to get it on and off without the extra ramps.
Reckon I can hold out a bit longer while I'm still able bodied lol
That trailer looks like it weighs a ton but of course it depends on the distances you tow and the load as to how relevant weight is. My 500kg Tilta Trailer is brilliant, solar panel keeps the battery charged, from Qld it's been to PI and Bathurst twice, slight buckle in one alloy wheel after hitting a monster pot hole at speed.
Probably not light, but I've never needed to go more than an hour down the road with it and the Silvia isn't too heavy.
I will say, I had to limit my speed to 100 when I towed the GT-R as it got a little wiggle on above that regardless of where I put it.
Yeh my Cherokee is rock solid towing at any speed including braking down hill, the PB Challenger diesel was a POS compared.  The C's long wheelbase with the rear wheels close to the towing point and generally good dynamics helps a lot.Engine just needs a chip.
Is it the latest one that has all the electrical issues?
For the price difference, gotta say I'm making do just fine with the Terri (free work car).
Though I was thinking about adding a trans cooler when I fit the brake controller for a pending camper purchase.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
