Goal = 400rwkw
I've got a fairly stock R34 GTT about to start modifying it to eventually reach my goal of 400kw. I've been looking into the precision 62/66 turbo as an option, sorta bias towards that option due to my mate having one spare I can get cheapish.
It ticks most of the boxes for the things I want in a turbo, only thing bothering me is that it is GEN 1. Is it worth saving for a GEN 2 62/66?
And it has a rear A/R of 0.68. will this be to small in a negative way? I think that a smaller A/R will give better low down tourq ect. Which is what I want, just doubting myself cause I see alot of recommendations for the 0.8ish size on similar size turbos like the gt3582.
Cheers!!
You'd want the CEA (ball bearing) version, and if you've got the budget to build a 400+kW Skyline then you won't shy at the cost of going with a split pulse/twin gate setup that's well designed (ie not a dodgy cheap China manifold and piping).
A 0.6x turbine housing would completely defeat the purpose of this size turbo, just choke the thing and frustrate you. I'd expect a decent setup on Neo 25 to perform best across 4500-8000rpm
An excellent alternative complete HTA3076 setup complete bolt-on capable of nearly 400kW is currently up for sale by 34GeeTeeTee. Well worth a look.
Im hoping for a turbo that has the potential to get to 400+kw but has decent response due to the car being driven on the street 90% of the time. From what i understand the 62/66 has the potential to exceed 400kw, but with the smaller A/R it will reduce the max hp output but increase the response. due to the turbo having the high hp potential (more than my goal) i can afford to loose some max hp and gain some response whilst still suiting my goals?
This is just how i understand it, please correct me if im wrong, still learning haha.
11 minutes ago, GTSBoy said:
Given that it's the wrong turbo, you'd better look at the various other turbo threads, especially the Borg Warner thread.
What do you mean by the wrong turbo?
cheers ill have a look at them threads!
Big flowing compressor needs to be matched with a turbine capable of flow.  Otherwise the engine effectively has a cork up its arse and can't breathe out.  So it won't get near 400kW, and streetable response isn't there.  Better achieved by using a different setup.
https://www.sau.com.au/forums/topic/426059-forced-performance-hta-turbos/?page=47
Edited by Dale FZ1
I have the Gen 2 6266 BB with a .82 rear housing... setup is not completely refined yet but its making ~20-21psi around 4700rpm, currently making 620hp on 23psi on a dynapack hubber..  forged 25 non neo with camtech cams and performance springs, the .68 rear will become a restriction as stated
Dyno sheet is in the rb25 thread
If you're on some what of a budget, don't discount @hypergear turbos. Their 45SAT will get you over 400kW and be decent enough to drive around town. I would recommend you go for the ball bearing version.
I've been believer of Hypergear Turbos since I started using them. I'm now on my 3rd Hypergear turbo (of course bigger each time) .
Yep you could always get the ss version of the atr45sat aswell
Think that comp wheel flows around the mid 400 mark
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
