Anyone with a coppermix competition twin plate holding 500kw?
As per title, got a new efr8374 on an rb26 and my current normal coppermix twin Is worn out and no longer doing its job. Will a competition version hold 500awkw?
That's really the most it's going to see with this turbo and its such a friendly twin plate I'm inclined to stay using one.
Intune and Nismo3.2ish both killed C spec coppermixes with the 8374. However, one is a 3.0 and the other is a 3.2. Pete's (the 3.2) nearly lasted a month.
It's more the torque that kills clutches. You may be right behind a 2.6L.
Damn, I hope the Coppermix Twinplate Competition that I just installed in my 8374 equiped R34 will hold then! It's just a 86.5mm/standard stoke Neo though, and RWD, so here's hoping...
Great You can be the guinea pig then! But being rwd you should be fine. They kind of act like a drive line fuse, you don't have that luxury with AWD.
Thanks for the feedback guys.
If 3.2ish managed to get one to hold on his car for a while before killing it, a 2.6 with 15-20% less torque should probably last.
Youre right. The question should  I have been who's making  900+ NM peak torque  a on a coppermix but most people only know their power figure. The plan is to keep the midrange torque In check to keep the gearbox and shafts alive anyway, and I have learnt the hard way that a super strong overkill clutch (RPS carbon) just breaks other stuff in a Evo.
Will have a look at the r3c, but the fact the centre isnt sprung is worrying drivability wise.
Cheers.
Edited by burn4005
I think the 2.6/2.8 guys should be ok. I ran a coppermix for 10 years (35,000 kms), power ranging from 370 rwkw to 470rwkw/800 nm of twist.
I pulled it out only after munching an OS gear set. The plates were just over half worn. It never slipped, never misbehaved and never refreshed or rebuilt. This was with OVER 350 big RPM launches under its belt.
To replace it went an OS88 and an R3C. The driveability is on par to the coppermix. It's definitely NOT a lightswitch it's just the pickup point is lower compared to the high pickup of the coppermix. Apparently there was a design change with the OS R series of clutches at some point, not exactly sure when it was though. Some time before October 2014.
Having said that, GTR_JOEY ran 430 rwkw on a 2.6L using the NON C spec coppermix for years and never had an issue. Only 30 ish wkw difference between the above mentioned 3.0 and 3.2, torque difference is a lot more.
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
