No oil reading and oil light flashing but has oil
So I have a weird problem where I have oil did the change about 2-3 months ago and now the dipstick isnt giving any reading when cold after wiping off. And when its cold after starting the oil pressure light comes on for a moment and does it randomly while driving not too often though. I know it has oil in it as it not puddling but yeah its got leaks. I put in another liter after seeing the dip bare but made no difference. So now I am not sure how to proceed and its my daily only one.
I have put another 500ml in and the light still coming on and still low reading. I will keep going when rain pisses off.
Had the car about 7 months always been funny with oil like heaps blow by and light coming on after oil changes etc. Has the no oil rattle when starting for a couple of seconds usually when cold.
Edited by HailDamage
where are you putting the oil in? does it have an extended or factory sump? if you run the car after topping up the oil and then open the radiator cap do you have a milkshake? is there a huge pool of oil under your car?
Into the oil fill port on the intake cam cover (making sure to be specific)
Factory and i have AWD motor if makes any difference
No it looks normal.
No there is a leak somewhere but its definitely no putting anything on the ground.
Stop guessing. Like Ben said drain the sump and see how much comes out. If it is new oil you can put it back in but make sure you put 5.5 or so litres until you see it on the dip stick. You say you have lots of blow by - what does your exhaust look like? You may be burning heaps. Do a compression test. maybe your engine is stuffed. If its not now it soon will be if you keep driving it with no oil pressure.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
