Tacoma WA, USA Newbie
Whats up!
Name is Dylan, Residing in Tacoma Washington, USA.
This is my 1989 R32 Sedan.
Got the car 2 years ago mostly stock and have slowly been plugging away at it, from stock body on 15's , to the current state of full kit, and 17's.
As she is right now:
SR20DET Powered, Tomei 256 cams, Greddy T517Z turbo, tomei exhaust manifold, Greddy intake, Nismo coppermix twin plate clutch, Nismo pressure plate and flywheel.
PS-Duce Front and Rear bumper, Origin sideskirts, Origin Front Fenders, D-max trunk spoiler.
Work Seeker SX wheels.
Nismo 2-way rear differential
Safety-21 Cusco Cage
Couple other goodies here and there, but yea!
  • Like 2
Welcome, awesome car.
Good to see you know how to treat it! :)
I would be keen to hear more about your builds and the details of your car. Especially if you're drifting it around the place.
Hope to see some more updates in the future.
  • 3 weeks later...
3 hours ago, DaymoR32 said:
Welcome to SAU, loving the car, any reason for the SR20 over on an RB25 swap? keen to hear more about the car!
At a guess I'd say that there'd be a lot more support and parts for SR20's in the states which would be a big plus for a project like this.
  • Like 1
 Share
    • I could show you guys photos of wrap having been removed properly, and where the wrap was removed, paint underneath is perfect. Sections of the vehicle didn't have wrap on it, and in those areas, the paint work is destroyed because of how long it had been sitting in the hot QLD sun for many many many years. Wrap even still looked decent. Good quality wrap, and removing it properly shouldn't rip off the paint work, unless the paintwork was already shot to pieces before hand.
    • Any write ups on replacing the window motor?  I've never messed with them (or window regulators) before.   Ever since I've had the car, the driver window would roll down just fine, but most often I'd have the try a few times to get it to go up.  As soon as it started to go up, it always goes up smoothly and quietly.  Seemed like a bad switch.  But now, its stuck in the fully down position and won't come back up.  I get =12/-12V coming out of the relay/amp when pressing the switch up/down.  So the switch and amp are working.  Just a bad motor.  I've also applied 12V directly to the motor and nada.   Any help on replacing the motor?  Can the glass and regulator stay in, and only replace the motor?  Or not possible?  Thanks!!!
    • You are wrong. That's just Whiteline going along with the incorrect slanguage of the sheeple userbase. They are only correctly known as anti-roll bars. They are only incorrectly known as swaybars. They do do anything to prevent "sway". The swaybars that are fitted to trailler hitches do prevent sway. In the trailer. And they do not look like anti-roll bars. So, take your incorrect infopinion away.
    • https://whiteline.com.au/front-and-rear-sway-bar-vehicle-kit-to-suit-nissan-skyline-r32-awd-9986-bnk009.html whiteline calls them a sway bar, the topic of this post.
