Suspension mods for an R34 GTT
Hey Guys,
What suspension mods would you recommend doing on an R34 GTT to improve the handling, currently the only suspension mods i have are some BC coilovers.
The car is my daily, it doesnt see any track use, just some spirited driving outside town around the windy roads where i live.
https://www.sau.com.au/forums/topic/471504-suspension-mods-for-an-r34-gtt/
Tein or similar castor rods with pillow ball front joints.  Far and away the best thing you can do to the front end.
Poly upper arm bushes are a good thing at the front.  Get them with adjustability to be able to tweak the camber.
At the rear it is a tougher thing.  There is no point in only doing a little bit.  Once you consider changing one arm, it becomes an all or nothing sort of thing.  But minimally, bin the HICAS and put in a proper eliminator kit.  With a good alignment.
After that, you're looking at the next "minimal" thing being to put adjustable poly bushes in all the upper arms.
After that....it's fully adjustable arms up top, with rubber outer bushes or even pillowballs if you give no fark for police attention and NVH.  But that it overkill for a streeter.
  • Like 1
The worst thing you can do is put pillow ball front joints in the car.  It will change it so that every bump you go over will be amplified through the chassis and annoy the hell out of you.  So don't do it.  Other radius arms are fine without such joints also - nothing wrong with bushes.
If you want to do something get good spring rates and good dampers and match them to sway bars.  Good alignment (including ride height), low unsprung weight and no HICAS is about as good as you can hope for.
As was said in the first reply - good tyres make a huge difference.
I still maintain that on front castor rods you can barely tell that they're there (from an NVH perspective) but that they work a million times better than even stiff urethane bushes.
I agree that they make life hard anywhere else.
Bin the BC junk and put something that's half decent in there.
Bushes! The more of these you change, the better. It's definitely a case of "oh wow, I didn't realise how bad it was" until you start replacing them OR changing arms that have new bushes in them. It is basically a 20 year old car. They're going to be flogged! Alloy rear cradle collars is a great place to start. The difference just by doing that is huge!
* Every arm on my own car is Pillow Ball and it's nothing like you guys are describing. You would hardly know!
  • Like 1
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
