12 hours ago, MrR33SKI said:
Turbo lol. Ive gone with a rb26dett for the 33 gtst. Cbf for the head aches of having someone elses thrashed motor lol. Ill see what i hit on the dyno and post pics here. Thanks for all the help guys
Umm yeah, that's like saying you hate guns then buying an AK-47.
Boggles my mind how people think the 26 is much of an upgrade over the 25. Older engine design with more flaws; GTR taxed parts and less availability; more prone to catastrophic failure...all for a negligible increase in displacement and a different soundtrack.
  • Like 3
Don't forget them all being thrashed.
At least the RB25DET has a better chance of being less thrashed, especially if it's from an auto car (e.g. Stagea).
And that the newest engine you'll get is already 15 years old, a lot if people dont even realise that some of our favourite cars like the r32 gtr are already 27 ish years old!!!
God damn dinosaurs
Edited by Cyko34
  • Like 1
Constantly trips me out that my R33 daily is older now than VH Commodores were when I first got my licence...I thought VNs were old shitters back then lol (they were)
Car is running perfect now. No issues st all besides having stock power. Have had a long think about it and came to the thought of just keeping the car stock and healthy. Also i have decided i would like to get a s15, evo7, and/or supra for a weekend car and keep the skyline as my daily.
This might sound stupid but if your burning through lots of oil check your PCV valve is working correctly
I’ve recently gone through a similar exercise with my Dads landcruiser which was using about a litre per 1000km
It’s done 305,000kms so we thought it was just worn rings. However I decided to pull out the PCV valve to check it, and it was stuck open. The vacuum hose going to it had split, so it didn’t have enough vacuum to open and close it and it got stuck
Cleaned it out with some solvent, put a new hose on and it’s using bugger all oil now, running sweet
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
