Modified r34 gtt part out
due to repair damage quote being a lot more then planned. i will be parting out my r34 gtt
car has all parts at the moment except front bumper passenger side skirt and passenger rear pod, both tail lights.
car is located in geelong and still drives on its own.
engine has 226,xxxkm all mods are less then 60k km runs fine no damage to anything mechanical just quater and end damage
quick mod list:
walbro 460lph fuel pump: $160
splitfire coilpacks: $300
tomei poncams type b: $600
bosch 100amp alternator: $120
ev14 725cc injectors: $500
 turbosmart hypergate 45mm external wastegate: $300
apexi avcr boost controller:  $400
plazmaman intercooler with cusom pipework (done by havoc fab will bolt onto standard pipework): $800
hypergear atr43ss2 turbo changed to V band external gate (2014 model and journal bearing ~50k km old): $900
nistune with flex fuel tune: $700
z32 afm: $150
full custom turbo back v band 3.5" stainless steal exhaust with magnaflow highflow cat (done by havoc fab) $1200
custom external wastegate off standard turbo manifold (done by havoc fab): $300
BC coilovers (no knocks or leaks): $800
npc 10" sprung button clutch: $500
hicas lockout bar: $70
work xd9 18x9 +30(front) 18x10 +38 (rear): $1400 (will no split set)
nismo clear indicators front and side: F: $100 S:$50
boost, oil temp, water temp gauges: $150 for lot
and all other parts avalible
buyer pays shipping on parts. pick up is fine also
first in first servered. no holds without deposit
will provide photos app on request. prices are negotiable.
happy to split parts (except wheels) or do deals on multiple parts.
if parts are not stated as sold, they could still avalible please feel free to ask.
please message me on 0431394082 or reply here or pm. wont always be able to answer calls.
  • Like 1
https://www.sau.com.au/forums/topic/472073-modified-r34-gtt-part-out/
Oh, it's OK.  I'd only be interested in the diff if it was fully sick Nismo 1.5 way hella spec stuff anyway.  Hence my question about the subframe.  Because if I was going to change from my S15 helical, then I'd need driveshafts.  And if I need driveshafts, then I could use his.  And if I get all that, then he might as well put the whole rear end on a pallet and send it to me and I'll transplant yet another rear subframe into my car and get improved late model geometry (which I should have done using an S14 subframe instead of a Cefiro one!!!farken!).  After all, it's only money.  And then if I have R34 rear brakes I might as well put R34 fronts on as well.
See how it all snowballs out of control?
:D
standard gtt brakes. the whole rear sub and drive line is still in tact, as for diff im hoping to have it out today or tomorrow around work :) will get back to yous
took an ass raping by a grass bank... bloody vic roads and their horrible pothole written uneven roads -.-
ive had a lot of interest for selling the car as is, for those who maybe interested. the car is NOT a statutory write off, it is still able to be rego'ed (after repairs). i just dont have the money to repair the damaged myself.
    • You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
    • No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure  Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect  After some googling about them it seems they added no power, but do increase some induction noise Meh In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with 12 meters worth of rock and cement Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 😢, the TLC I can provide, and nature over time will do the rest And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer Meh, all in all I'm having fun and keeping busy, plus, it's good PT
    • If I drove to a typical petrol station, what would my choices of fuel be?
    • Just cut the bottom of the guard out. It's no longer got a big duct, to a sealed box, or a restriction. It has all the cold air from outside. Also, that cai you showed looks terrible. Bends are NOT good for go gos!
    • Like I said, "black magic" LOL In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay  Famous last words: I cannot see it being any worse than what it is at the moment 🤔
