Hi All,
Yes.. I know this topic has been beaten to death, however im in a bit of a predicament (1st world problems) and would like your assistance :)
I just got my car tuned on e85 running 2859-9 turbos, the car made 355rwkw on 20psi  however i was informed that my current exhaust was holding back the turbo (and response). I am currently running a turbo back (3inch?) titanium fujitsubo exhaust which is a twin pipe design and flows out into one larger muffler with an Apexi Cat, it is super quiet which i love, unfortunately max output is 350kw.. I was advised to go for a 3.5 - 4inch exhaust but the problem is i cant find any for a R34 GTR! I can only find ones that fit R33 (i.e. HKS hiper) that are reasonably high flowing.
Does anyone know any other exhaust manufacturers that will help solve my issue? I cant seem to find resellers either :(
Or if anyone wants my quiet titanium exhaust for their louder free flowing exhaust, happy to trade with cash adjustments! :D
https://www.sau.com.au/forums/topic/472203-exhaust-for-r34-gtr/
+1 for the HKS super turbo muffler. It is straight through design with no restrictions or reduced diametetrs inside the mufflers. I just bought one second hand on BidJDM for $500 plus shipping. Quiet too for a straight through design. Have a look on youtube.
  • Thanks 1
2 minutes ago, choyda said:
Check out AM Performance - they did my Titanium 3.5".  They're Adelaide based but Andrew can make one regardless - just make sure you're running an R34 sized cat, not an R33 one (shorter).
Will suss them out too! Another titanium would be nice
Get the entire exhaust. Remove it from your car and flog it on ebay. You can build a very very good 4" system that is very free flowing with a nice quiet note and no drone. Honestly, the off the shelf stuff is literally shart.
  • Like 3
I have almost the exact same combo, but I have cams.
I had my fabricator make me a custom setup so my exhaust is as follows.
  • HPI 3" Dumps.
  • HPI 3.5" front pipe.
  • Full 3.5" Vband exhaust, "special high flow cat".
  • Magna flow mid muffler.
  • Apexi Evolution Rear muffler.
Car is quite and makes good power.
I will say you wont make much more power by changing exhaust until you put cams in it.
  • Like 1
Ill have a look into it. It seems custom is the way to go. Will speak to an exhaust shop, i wouldnt mind modifying the HKS exhaust, however if i can get the same quality if not better for cheaper then will take a different route.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
