What is the power range you want, and your setup etc?  It's hard for anyone to tell you which is better suited when you've mentioned two turbos which flow different to each other.  I'm personally not a huge fan of either in the current market, much better options for what both can do out there now.
The power range id like, would be around 350kw and at the moment the upgrades are, 750cc injectors, link G4 ecu, front facing plenum, 6 boost manifold and so forth, if there is a better turbo that is more suited for the type of set up I’m after, which would be more street but occasionally track.
Edited by Fr3akyR33
Ah that makes life simpler.  On 98 octane?   I can say straight out, a GT4088R is overkill for that power... though these days a GT4088R is pretty much pointless in every way unless you are pretty much given it.
Edited by Lithium
  • Like 2
For simplicity go internal.
External means you'll need a new manifold, dump pipe, wastegate, plumbing so on and so forth.  To go drive in drive out with a new external gated turbo you're probably talking $6k including turbo.  To do it internal you're looking at half that including turbo. (That's JUST to buy the turbo and have it fitted - NOTHING ELSE)
Note, you're going to need a hell of a lot more than just a turbo to hit your power goal.
350kw is going to be a $10k-$15k spend.
Turbo
Cooler
Injectors
ECU
Exhaust
Coilpacks
Clutch
AFM
Filter
Fuel pump
Fitting parts
Tuning
I suggest you stop worrying about specifics, ie. which turbo, and spend the next 6 months reading and researching these forums as to what you're getting yourself into.  It's clear you have absolutely no idea so you need to research like a madman.
Start researching for a well regarded workshop near you who you will get to do the actual work and then work with them, as well as what you can learn here, and start buying all the pieces you'll need to complete the jigsaw (after lots of research).  If you rush into it and start hanging all sorts of random shit off your engine, you'll end up spending $25k and you'll get a shit outcome.  Research, patience and knowledge is your friend.
Seriously for what you want just shove a gtx3071, a good exhaust and intake, a good cooler, a fuel system to feed and an ecu to control it and a clutch to hold it
and if it's a 33 engine save some money for a bottom end cause it'll hurt a rod eventually
  • Like 1
  • Thanks 1
If it is purely for street use and not used in a competitive motorsports environment, then 300kW is plenty for a car with basic suspension modifications (i.e. a set of coilovers) and the factory LSD.
270~300kW is very achievable with a small budget and will be "fast" enough and "fun" enough.
Once you start go to beyond that, expenditure increases exponentially where as before that it is linear some what lol.
Hypergear ATRG3SAT would easily do that on 98RON and give you a bit of headroom in future if you ever decide to spray some WMI or go E85.
Another question before you start throwing out turbo makes/models etc. is when you want the turbo to come? yes any big turbo can "make" the numbers you want but when is another question?
No point slapping a biggish turbo on your car to make only 300kW and have it come on late - very american mentality. "oh be dayem, it makes 500hp on a mustang dyno, and I dont' mind the lag because I'm american"
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
