I have ordered new o2 sensor and coolant sensor, I get terrine fuel economy and a miss I'm idle so it's on its way out, and have ordered coolant temp sensor. I don't know for sure it's but the car never gets to operating temp on the dash dial. It sits a 8 o'clock sorta angle. What I read was that the coolant temp sensor can cause the huge regarding of the vct and running rich because it thinks the engine may be over hearing as sorta protective mode. I had intermittent check engine light when engine would ping hasn't pinged since new coil packs however. So from what I hear it is pre ignition will update once I install the new sensors holding for the best
  • 9 months later...
Hey, sorry to bump an old topic but I didn't want to create a new one as this is very similar to the issue i'm having.
Curious if your repairs sorted out your issue? I've replaced coils, plugs, soldered the MAF and fixed a vacuum leak but my car still doesnt like revving past 5k once its hot. Doesnt matter what gear, can even be neutral. Just breaks up like crazy :(
It reaches full boost well below 4k(got the restrictor bypassed) and holds fine until 5k. It also does it even if i just use partial throttle, so I dont think fuel or boost leak is the issue. Its running the stock original fuel pump but I can smell lots of fuel when It does it in neutral.
i'm wondering if my MAF just isnt any good. Or for some reason its not getting sufficient spark. I'll have to re-check my plugs and maybe swap a known good MAF. It just started all of a sudden. It ran mint up until a few weeks ago.
Edit: i'll check out the ECT sensor. My gauge reads fine and dandy as always but ya never know!
Edited by Ryno34
  • 2 months later...
It seems fine in all weather until it gets to operating temp. Even once warm it still idles and drives fine. It’s just when I try to put any power down above 4k rpm it sputters and pops like crazy. It’s frustrating not being able to use the fun half of the rev range haha
Edit: It also does it if I bring the revs up slowly, and does it in neutral. Boost is good until 4k. Then it obviously starts dropping as the engine starts to misfire.
I tried pushing to redline the one time and it just wouldnt make it past 5500. The cloud of smoke behind the car was rediculous haha so its getting fuel. It holds max boost until it starts to misfire so I can only assume its not a boost issue(maybe i’m wrong?).
i dunno. Cars....
Edited by Ryno34
That sounds just like the problem i am javing mate.  Mine runs prefect when cold and as soon as it gets to op temp the boost wont kick in till about 3k rpm and then after 4k rpm it pops and cuts in and out.
I have tried new spitfire coils and plugs gapped to 0.8mm, manual boost controller and redoing vac lines and its still doing it
Could be fuel related. But it seems odd that it would be fine (did a 7krpm pull) without issue when it was just below its normal operating temp on the gauge(I know, I know, just wanted to test).
i also find if I sit in traffic for a while on a hot day, the rpm at which it starts acting up drops significantly. Like the one day I was in stop and go and it was doing it at around 3000rpm.  Almost like something is getting heaksoaked. It feels like weak soark/coils but i’ve tried two sets of coils and plugs lol
  • 5 months later...
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
