I picked up my Q60 from Sutton Infiniti in Rosebery Monday and I have driving every second of the day enjoying my new toy...
This whip is completely a new beast and Infiniti has done a good job.
The hiccups,
(1) Drive by Wire, well, you will need a bit of patience but that’s no different then hopping in a R35 from a V35.
(2) 19” 245 are just to small
The good news
Fast and I mean fast not just quick!!
A head turn
Infiniti and Alpha Performance USA have teamed to created Mod parts and possibly a car together
Turbo lag.... well, let be straight with you, there isn’t any because the torque kicks in at 1600 rpms
Technology... it’s a Nissan enough said!!!
Edited by wizlb
  • Like 2
https://www.sau.com.au/forums/topic/472571-q60-just-purchased/
Absolutely love it! One of these is next on my shopping list also. I have been toying with the idea of getting a Q50 for a couple of years, but now the Q60 has come out with the 3.0LTT it is the way to go.
  • Thanks 1
I drive it in sports+ around the city and sport on the hwy. I will put up some new pics up soon.
If you are serious about buying a Q60 then try to get a 2017 because the new 2018 will land soon and the pressure will be on the dealers to unload current stock.
The main differences between 2017/18 are the tires... 19” verses 20” wheels
If you can find a demo model snap it up fast!!
Edited by wizlb
  • 4 weeks later...
Looks great, I love the look and size of them.
Bits it shares in common with R35 and the packaging puts me off a fair bit. Sounds like a complicated beast. Certainly wouldn't want to work on it myself.
^^ they certainly do. I had a black 280rwkw R34GTT in black and swore I would never own a black car again ... then found my current V35 in a yard and instantly fell in love with it - in black of course ... and here I am hating keeping the thing clean, but am thinking of upgrading and loving of course a black Q50 or Q60. Hmm decisions, decisions!
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
