FOR SALE
PRICE REDUCED!
$94,000 now $89,990 or $69,990 (excluding Holinger sequential & NPC clutch)
1998 SERIES 3 R33 GTR
Car has had no expense spared – full Nitto 26/30 build, Holinger sequential, immaculate inside and out.
Made 520kw at 23PSI on E85, plenty more in it however that was more than enough for me (in fact I rarely drive the car; the car has been de-tuned to only 14psi which is still plenty for me).
Car is immaculate and most parts new, have receipts for engine build, Holinger etc; dyno sheets and receipts will be provided.
ENGINE:
RB30 block
Nitto JE piston
Nitto I-beam
Nitto crank collar
Nitto head return
ARP main
Arp head
Nitto head gasket
ACL race bearing main
ACL race bearing rod
Grout fill block
Greddy oil pump
Tomei type B pon cams (260, 9.15IN & 9.15EX)
HKS cam gears
Supertech titanium head kit
Street ported head
Ati 1000hp balancer
Nismo thermostat
Setrab oil cooler set up
GTR Pro Motorsport crank & cam trigger kit
Spit fire coils (blue tops)
Racepace oil catch can
RIPS sump
RIPS RB30 adaptor plate
Aluminum radiator
ECU:
Autronic SM4
Haltech ignition
Full flex fuel set up
TURBOS:
Twin GTX
N1 Turbo exhaust manifolds
Custom 3" Intake Pipes
Ceramic & Powder Coating
FUEL:
Twin entry fuel rail
Magnafuel fuel pressure reg
Magnafuel 750 4303 pump
Magnafuel filters
Custom surge tank
Walbro intank
2400cc Bosch injectors
Fuel pressure gauge
Flexi-fuel kit
DRIVETRAIN:
Holinger sequential with pressure sensitive gear lever and display
NPC 1000hp Twin plate clutch
Nismo short shift kit
Nismo 2 way diff
Gearbox transfer case modified
Alcon front brakes
TE37SL x 4 10.5 +15
Hankooks 285/35/18
EXHAUST & SUSPENSION:
Full Racepace 4” exhaust
TEIN suspension
Adjustable control arms
OTHER:
Top quality alarm system
Top quality sound system
Brand new xenons
New badges etc
Sparco quick release with RPM when (can supply immaculate standard wheel also)
Car has 12 months rego, ridiculous offers will not even get a reply.
  • Like 1
Wow can't believe you're selling :O
Going to replace with anything?
One fastidious owner for those interested, this car sounds amazing and inspired my cam choice ;)
  • Like 2
Hey mate, nah not going to replace with anything. If I don’t get a good price I’ll just keep it. I am only looking at selling to help build a house.
  • Like 1
  • 1 month later...
Sooooo sexy man, surprised it hasn't been snatched up already. One day when the time and funds are right I will own a car with a sequential. End goal!
GLWS, beautiful car.
  • Like 1
KR4 was R34 colour, like mine.
Daz you should give me this car, including all the good bits and like 50k..
Sure, that would be a massive hit for you, but it would be great win for me, and that's what really matters ;)
GLWS - god I love this car.
Sell yours and buy mine ;)
Good luck with the sale of yours also!
  • 3 weeks later...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
