Yo!
so yesterday my s2 R33 rb25det was working perfect never had an issue. i get in my car i go for a drive i go to hit boost and its struggling, it sounds like i have a bee r limiter but no power at all just making mad pops from the exhaust. the factory boost gauge shows its working but yeah no power and it struggles real bad.
i have checked all the piping and lines. no leaks or splits.
if anyone has gone through this or knows how to fix it please help. i just wannnaaaaa hit boost :(
https://www.sau.com.au/forums/topic/472876-r33-misfiring-trying-to-hit-boost/
stock ecu. 11.5psi. s2 r33 turbo. there is a paper in the car that its been tuned to 11.5psi. but doesnt feel like it. i changed the spark plugs seems to be working a little more better now. just gonna scope out for leaks with air compressor. i was hoping nothing shorted when i was using a light test and accidentally hit the smoke lighter and it sparked
hasnt been tuned for a few years. i have a dump and highflow cat and looked inside it no cermaic wheel bits. ive just put gasket maker for bov. tighten up everything else and install a boost a gauge tomorrow and see whats going on from there. its stopped misfiring. boosting better now. but feel like its lacking 10% of power i reckon but i'll let gasket dry over night and see how she goes in the morn.
Turn down the boost, your car isn't tuned.
You cannot tune the stock R33 ECU unless it has been remapped by Toshi or by those off the shelf remapped Nap ECUs (totally useless with Australia fuel and climate).
update* seems to be running better now. it ind of slacks but its getting there.
also i noticed after putting gasket maker for bov. when cold it kinds of flutters a little and makes a weird little metal noise after dose for under a sec. but once its warmed up it goes back to whoosh sound and no metal noise :/
strange. now its starting to do it again.
so when i put my foot down as it gets around 4-5k mark it looses power even with my foot on the floor it doesnt wanna go anywhere. i try it again and boost will come on i try it again it wont want to move... so confused
Edited by AndreW_R32
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
