I was reading about a guy in the states who did a 'LCI conversion' to his E90 by sticking red tinting on his tail lights. While this is in no means an 'LCI conversion' I thought it looked so much nicer than the clear reverse lights so I bought some pre-cut tint from the states and put it on today. Its not perfect with some tiny air bubbles but I'm hoping that by leaving them in the sun they might go away, I think it looks so much better as the tail lights are, for me, the weakest design link on this car.
  • Like 2
imageproxy.php?img=&key=4b1e78680f916b86
Um but do they glow red when you are going backwards? Would be illegal and confusing.
  • 4 months later...
I just realised how long its been since I updated this.
So, I'll add what I've done since March.
Oh, also, my VVT motor is leaking oil into the spark plug holes #3 & #4. Its not much of a leak but its causing the odd miss which is irritating me. Been quoted $800 but it looks pretty straight forward and might give it a go myself.
Also, during my must-keep-warranty 6 month oil change my intake pipe was noticed to be not entirely attached allowing unmetered air into the engine. This was fixed which made the car a little more responsive.
I changed my angel eye bulbs to LED's. I purposefully didn't get stupidly overpowered ones as I didn't want the angel eyes to be like little suns, I just wanted them whiter than the halogens and slightly more noticable.
Here's drivers side done, but not passenger. Fairly different, passenger doesn't even appear on.
Both done in the daylight.
Here they are at night. Not bright enough to light anything up, which was the desired effect.
I need to get pics of my interior changes...
But, I totally had enough of my seats. They were horribly uncomfortable and like sitting on a bench.
I got some absolutely mint M-Sport seats. They are soft and the leather is gorgeous. Lots of left and right thigh support and an extended thigh base at the front. They also have air-filled bolsters though if you are larger than the average 3 year old you may need to leave them empty as they get seriously tight.
I also picked up a BMW Individual steering wheel! Its so fricken cool though a little banged up. I'm trying to bring it back to its former glory but its already so much nicer to drive with than the bus wheel that was in it before.
One thing I noticed on the car the first time I saw it was the terrible state of the window seal trims. The front windscreen is totally missing and the rear just looked horrible.
Here's how it looked and it was killing me every time I looked at the back of the car.
The other issue was that somebody had glued these pieces on which was a real mess.
Anyway, once they were all off I gave the glass and the car underneath a good clean and then a spray with silicon to assist in getting the new trims on.
End result is so nice. Its one of those changes you make that you keep noticing every time you look at the car. Seriously satisfying, its been eating at me since I bought it.
Some black glue still on the paint to this day, need to hit it with some bug and tar remover.
Passenger side isn't perfect but no amount of manipulation would fix it. I just left it, as its not glued in I might try to fix another time.20180721_150442.jpg
My drivers side tail light has always been cracked. I picked up a replacement and its another satisfying fix. Its so much cleaner than the other side though I'm now considering buying its pair to make both sides nice and clean.
Anybody know how to get this off? Its so irritating and no amount of scrubbing even makes a dent.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
