I was reading about a guy in the states who did a 'LCI conversion' to his E90 by sticking red tinting on his tail lights. While this is in no means an 'LCI conversion' I thought it looked so much nicer than the clear reverse lights so I bought some pre-cut tint from the states and put it on today. Its not perfect with some tiny air bubbles but I'm hoping that by leaving them in the sun they might go away, I think it looks so much better as the tail lights are, for me, the weakest design link on this car.
  • Like 2
imageproxy.php?img=&key=4b1e78680f916b86
Um but do they glow red when you are going backwards? Would be illegal and confusing.
  • 4 months later...
I just realised how long its been since I updated this.
So, I'll add what I've done since March.
Oh, also, my VVT motor is leaking oil into the spark plug holes #3 & #4. Its not much of a leak but its causing the odd miss which is irritating me. Been quoted $800 but it looks pretty straight forward and might give it a go myself.
Also, during my must-keep-warranty 6 month oil change my intake pipe was noticed to be not entirely attached allowing unmetered air into the engine. This was fixed which made the car a little more responsive.
I changed my angel eye bulbs to LED's. I purposefully didn't get stupidly overpowered ones as I didn't want the angel eyes to be like little suns, I just wanted them whiter than the halogens and slightly more noticable.
Here's drivers side done, but not passenger. Fairly different, passenger doesn't even appear on.
Both done in the daylight.
Here they are at night. Not bright enough to light anything up, which was the desired effect.
I need to get pics of my interior changes...
But, I totally had enough of my seats. They were horribly uncomfortable and like sitting on a bench.
I got some absolutely mint M-Sport seats. They are soft and the leather is gorgeous. Lots of left and right thigh support and an extended thigh base at the front. They also have air-filled bolsters though if you are larger than the average 3 year old you may need to leave them empty as they get seriously tight.
I also picked up a BMW Individual steering wheel! Its so fricken cool though a little banged up. I'm trying to bring it back to its former glory but its already so much nicer to drive with than the bus wheel that was in it before.
One thing I noticed on the car the first time I saw it was the terrible state of the window seal trims. The front windscreen is totally missing and the rear just looked horrible.
Here's how it looked and it was killing me every time I looked at the back of the car.
The other issue was that somebody had glued these pieces on which was a real mess.
Anyway, once they were all off I gave the glass and the car underneath a good clean and then a spray with silicon to assist in getting the new trims on.
End result is so nice. Its one of those changes you make that you keep noticing every time you look at the car. Seriously satisfying, its been eating at me since I bought it.
Some black glue still on the paint to this day, need to hit it with some bug and tar remover.
Passenger side isn't perfect but no amount of manipulation would fix it. I just left it, as its not glued in I might try to fix another time.20180721_150442.jpg
My drivers side tail light has always been cracked. I picked up a replacement and its another satisfying fix. Its so much cleaner than the other side though I'm now considering buying its pair to make both sides nice and clean.
Anybody know how to get this off? Its so irritating and no amount of scrubbing even makes a dent.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
