HI All,
I'm moving and have these to offer:
Pick up in Greenacre - 0414 509 399 Spiro
R32 GTR Engin wiring loom $300
RB26 sandwich plate with throttle bodies and linkages
HKS R32 GTR coil overs - $800. Front top hats show some wear but work well.
Buddy Club coil overs - $300 - One of the rears is dead. Buy the fronts and get the rears free. Came with the car dead.
Zeal coil overs - $300 - One of the rears is dead. Buy the fronts and get the rears free. I killed this one.
Front Hubs $50 each
Coil packs, brackets and Harness - $200
Mirrors and Tail lights, $25 each,
ABS - $50
steering surround - all four parts $40 - I cant see the key lock piece.
r32 gtr Attesa oil reservoir - $60
Power steering reservoir - $25
R33 GTR muffler $100 -
R32 front sway bar, brackets, and links. $50
eXedy twin plate - I need to pull this apart to see the wear and tear - Let me know if anyone is interested.
Nissan cooler box???? funny. Pulls out of glove box.
20171212_184702.jpg.5036a7c98815f590556a42805f5cc7c8.jpg20171212_184706.jpg.5cd68c2357ba440a40f048c4a3d3b911.jpg
Managers here now so i cant finish this post..... Im just going to add the pics, Als im tired now. let me know if you see anything in the pics that you want. parts from $5
20171212_184434.thumb.jpg.0e5f846d235c31b2b812fcac4d281120.jpg20171212_184431.thumb.jpg.a7421121c1558df977069323e5c37eeb.jpg20171212_184425.thumb.jpg.194f0f475a4cf9a576b5852fa480d091.jpg20171212_184422.thumb.jpg.0d276c9355f9f9af07d4579ff6690e60.jpg20171212_184416.thumb.jpg.f504a49cffb94a976f8a5b445a4cedf4.jpg20171212_184436.thumb.jpg.e5fae87db5c036be0ec917eace4153d8.jpg
20171212_184405.thumb.jpg.d2fa3eebeaae265275677f2fc05ae0ba.jpg20171212_184408.thumb.jpg.a7d551dc7b04c109abc00f322e5eed42.jpg
20171212_184744.thumb.jpg.64a2de0fd36b86a7a9cb2418a69a97c8.jpg20171212_172722.thumb.jpg.811ef537131d3143ada9472ef41c21a9.jpg
Cheers
imageproxy.php?img=&key=4b1e78680f916b86imageproxy.php?img=&key=4b1e78680f916b86
Edited by spirom
https://www.sau.com.au/forums/topic/472909-r32-gtr-parts/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
