I mean, I think half the reason  they sound so good is  because they are not using traditional  merge collectors. The original gtsr unit has a flat style collector, the reproductions shown in this thread have angle-cut pipes, but the collection is still "flat".
Could  one not just use two 3-1 flat collectors and the exact same pipe lengths as the original item?
Then again,  I can't fabricate so I could be missing something obvious here.
Whilst i would absolutely love a genuine R31house item i would never support speedtek in any way shape or form, even if i was receiving a free manifold from them. f**k speedtek.
  • 3 weeks later...
The speedtek manifolds don't even come close to the quality of the R31house equal length, single piece, hand bend runners.....
They're no where near equal length either.
I've spend literally hundreds of hours searching and attempting to translate any info over the years on gts-r manifolds and especially the R31house manifolds and his journey to recreate "that sound" and from what I have found, there's been three iterations all up now.
The first was the long large diameter merge type:
The second iteration is the one I have called "max" :
And the latest version 3 is the "premium" which just launched a few months ago, here's a pic of one with an original gts-r:
I managed to translate a blog post from R31house from a few months ago stating that the particular sound that R31house refer to as "that sound" comes from the pressed plate steel merge collector on the original Hr31 gts-r manifold and they've only now with modern tech been able to 100% recreate the original and finally achieve the 20 year long goal.
Another interesting translation was that he said he felt his car lost response and power with the v3 "premium" compared to the v2 "max" because the runners end at the start of the plate steel merge with the openings facing directly at the inner front flat face of the merge collector and this creates turbulence BUT is the precise cause of "that sound".
I also have seen two versions of the actual RB20det-R GTS-R manifolds as well, the normal 1-800 homologation Hr31 gts-r manifold with press bent like runners and heaps of splatter from the welds Etc.:
Then there's the Hr31's that the racing teams like Reebok, Calsonic and Gibson etc. received and the manifolds they had was the same design with much, much higher quality materials, runner bending and welding...
The ReeBok car:
I even tracked one down 5-6 years ago on a sale thread and contacted the guy selling it and it turned out he was an actual mechanic for Gibson Motorsport and the manifold he had (sold) was unused because when they received the hr31 race cars, Gibson removed the manifolds immediately in place for the custom Aussie made Gibson manifolds, this is that actual for sale thread photograph:
And obviously this is the Gibson manifold:
*all photos taken from google
  • Like 3
I genuinely love these manifolds and live to share the information to those who also have a genuine interest (:
And I have actually left out a couple of others hahah...
The Hr31 Autech had shorter runners and a smaller merge collector into a t28 flange which was widely rumoured to spool a lot faster and produce better numbers than the gts-r manifold even though it's wasn't equal length:
R31house has also done a couple of the Autech recreations in the "max" v2 style, note the unequal runners:
  • 2 months later...
Just had this arrive fresh from the motherland, a piece from the owner of R31house’s personal inventory..... A brand new completely unused GTS-R turbo manifold still with the original Nissan part number label on it ?
Feast your eyes.....
  • Like 1
  • 1 month later...
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
