Hello.
i have a r32 gtr, and a have some little misfire in high rev.  I want to buy splitfire ignition system + do luck harness.
But i have a simple question for australian people, because in France, i have not a clear answer :
if i install a r34 ignition system, can i remove the ampli (power transistor) ?
thanks.
(I'll do a quick research, but hard to find answer with my limited english)
https://www.sau.com.au/forums/topic/473693-ignition-system-rb26-r32r34/
Yes, you can change from dumb coils that need the ignitor box to coils that each have an ignitor built in.  You will obviously need the appropriate harness, and you will still have to adapt it to the R32 harness, because the power and the triggering wiring are all based around the ignitor.  The new coilpack harness will not simply connect to the old body-side ignition harness and just work.
Thanks for Quick answer.
Is the r34 coil have an ignitor built in ?
for the harness, i simply think to buy the r34 do luck harness, replace and wiring the r34 connector with r32 connector, and remove my ignitor box (ampli). Is there something that i forget ? Is it more complicated than that ?
I may have to do a quick back-pedal here.  I was allowing what I know to be true for the differences between R32 (RB20) and R34 (RB25Neo) coils to pollute my thinking on the RB26 coils.  I put my hand up and declare that I do not know for sure what the situation is with R34 26 coils/igniters.  But if there is no change (ie, they still use an external igniter) then, no, you can't throw the igniter away.  If they did switch to internal igniters, then my first post is correct.
8 hours ago, Anonymouse said:
I thought you were trying to get rid of the Ignitor?
sure.
That's why i want to install R34 coils. A friend with a BNR34 confirms me he have not ignitor in his engine bay with oem coils.
It appears that the Splitfire DIS5 that suit Neo RB25s are also claimed to be correct for R34 RB26s.
https://www.rhdjapan.com/splitfire-super-direct-di-ignition-system-bnr34-r33-c34-y33-wgnc34-wgn34.html
That would make more sense than Nissan just sticking with the shitty old coils they used on the 32 & 33 GTRs, which were the same as the RB20s.
Bnr 34 coils have inbuilt ignitor and mount the same as r32/r33 coils ie the 2x 3 aluminum x shape brackets, they aren't the same as r34 neo coils mounting wise.
The bnr34 coils use the same plug/wiring sequence as r35/vq coils.
I've fitted neo coils to a vh45 eliminating the ignitor from each bank. Was pretty straight forward, I changed the pin location on back of plugs and added a +ve to each or from memory. Was a while ago.
Thanks mates.
@Anonymouse : thanks for the link. But someone said me r35 coils need to remap the rb.
@Griffin & @GTSBoy : thank you. So, i will buy the splitfire bnr34 coils, with the doluck r34 harness. I'll let you know in a few weeks.
  • Like 1
  • 1 year later...
I found these on ebay and was thinking òf using this rather than relying on the igniter. What do you think GTS BOY?? Also will I need to return after I install??Screenshot_20200405-095623_eBay.thumb.jpg.b9e69862e9b0ba1be50def31920cc6f4.jpg
Edited by Impulr33rowner
The Kudos motorsport kit is the go for what you're talking about without going the R35 coils. As mentioned retune not required, although if you have the ability in your ecu there is a slight reduction in dwell time compared to the 32/33 gtr coils. Would probably ok not to adjust but they are different FYI. Also as mentioned that wiring specialties coil harness also suits the R35 coils if the 34s don't have enough punch for you.
97E9C8D7-2544-4710-BC7A-0CD408D695F3.jpe
That's my 1993 r33r impul, with 2.6 conversion and pushing well over 500hp. I know the igniter will fail again sooner or later so I will go ahead in the very near future with the igniter coil packs. Also I would like to change the pulley to a serpentine set up. Anyone done that and got any idea if there's a kit available?? I also need to chase up a heat shield for the air filter, if i could get cooler air in should help performance too surely??received_733672663834867.thumb.jpeg.a992d2ed1801b52ffcbbf23d5f6558c9.jpegResized_20161015_085040001_3771_1572238889372.thumb.jpeg.483614ec96a48f0864faebc834ac1a31.jpeg
Also can you buy a pinion/ driveshaft bearing and seal kit for my abs locker diff r33??
Cheers for your advice and I think it will be a more reliable system. Whenever the engine sounds not quite right I always think not another igniter! I was lucky last time just a fouled plug!!!
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
