R33 gtst Slight missfire on idle... Spark plug gap suspect
Hey guys, ive done some reading up on this but want to get other peoples opinions on changing spark plug gap and whether it will affect my tune. So far i've checked coil packs and replaced with brand new splitfires, new ignition module a few years ago, new fuel pump and injectors, New z32 afm, all vaccum hoses replaced as well as headgasket and intake and exhaust manifold gaskets with genuine nissan items. Tps and aac valve are both relatively new as well. Car is tuned on e85 running a power fc. Made 408rwhp on stock motor and pulls hard with no missfires or hesitation. The only time it does miss is on idle and seems to splutter a bit under 2500rpm. Its only a very slight miss like a cylinder dropping sound but is more noticeable when warmed up. Im running ngk bcpr7es plugs gapped at 0.8 but was wanting to see if 0.9 gap would iron out any idle miss im having and not massively affect my tune. Cheers guys
^^^ as per GTSBoy says, That gap is only needed when you're boosting.  At idle or just above, it won't matter.  Generally at idle you could have just about any gap in the 1.2 to 0.8mm range and it wouldn't matter.
See if it still happens with your A/C turned off.
Cheers for the input so far guys. So with the a/c switched on there is literally no miss! It idles at 1000rpm but the miss comes back when its switched off. Once the car is at operating temp it idles at around 850-880rpm. I also noticed when i unplug the o2 sensor the miss goes away completely but the afr's drop to around 13 on idle instead of sitting on around 14.7 which i imagine is normal as it was tuned with the o2 sensor. Does this mean theres an issue with my o2 sensor or possibly the wiring?
Missfire on idle? That's just called 'having any RB engine'
Thats what the tuner said too lol he couldnt pick up any faults with anything but surely it cant be normal. It sounds shit on idle! Slight miss every few seconds rather than idling super smooth like it did before. Oh well i might just have to live with it then
O2 sensors get old and slow.  The heaters also stop working and they don't then work when cold (ie at idle).
O2 sensor was also replaced not too long ago with a genuine nissan sensor as previous one was getting on.
Just an update guys...had a mate of mine double check the gap on my plugs and turns out it was only around 0.5mm! Pretty pissed off as a reputable tuner gapped them for me too! Anyway they're now gapped to 0.8mm and no more miss what so ever and the car obviously feels smoother too. So...yes, spark plug gap can affect a cars idle lol
I wouldn't call someone that doesn't know the difference between 0.5mm and 0.8mm spark plug gap a reputable tuner. Did they have a reason for the small gap?
He didn't mention anything to me about the small gap. He told me he was originally going to gap them down to 0.8mm. The plugs really shouldnt of needed much adjusting anyway as the bcpr7es come pre gapped at 0.8mm. He was also trying to say the miss was a 'skyline' thing lol the car feels great to drive but now im a bit skeptical on the tune if he cant even gap plugs.
Yeah I'd be too. It's strange when people say "reputable tuner", where did they get the reputation from? Instagram/Facebook or here on SAU? Or did they start off good and then got lazy/sloppy/dodgy (reminds me of a certain welder)?
I totally agree with you! The tuner did look after me though during the whole process and didnt charge me for a couple of dyno runs as we were diagnosing issues. And from what i could tell, he was a very honest, upfront guy. A mate of mine recommended him and a few of the boys on sau have had good results too. Im not too familiar with the pfc hand controller but is there a way i can view the fuel map/settings and post a pic on here so someone might be able to tell me if it looks like a decent tune?
On 28/04/2018 at 7:52 PM, Ben C34 said:
Keep in mind it probably wast the turner who gapped the plugs, could have been a different guy so not really fair to blame one guy
Yes sorry, I meant to finish off my previous post with this but I got distracted and hit the post button too early.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
