10 hours ago, Ben C34 said:
Bushed?
Make a bushing the size of the head stud hole with clearance for the stud in the hole, than install with sealant, stops any possible transfer of coolant. Bushed holes should have sealant on the head stud instead of arp lube
  • 3 weeks later...
  • 3 weeks later...
Block didn’t take long to get built and shipped. It landed this past Friday at the shop. It was a smooth and easy business transaction with the shop in Canada. Also the Unigroup camshafts came in. Got them fitted up and ready to send the head off to get cleaned and the New valves (guides and seals) installed. More to come....
  • Like 1
  • 1 month later...
  • 3 weeks later...
A little more progression photos:
had to order 28 shims from SuperTech to get to this point. But finally both intake and exhaust completely done. Waiting on the head gasket now. (It’s enroute). It’s a tight fit! :)E16C171C-2BBA-45B1-BB2A-9FA2E70D45BF.thumb.jpeg.88309d270b3969f74fe679960172c802.jpegB5779B50-9704-4C9C-ACF1-BAB365824A5E.thumb.jpeg.a0e85ba33b2c93596ea52d69aabf6fa3.jpegD270A4E3-BB28-419E-9780-ADABC53C2592.thumb.jpeg.d0a08a537d414127adb98e196cc54333.jpegFA7C87E8-09EB-4F2B-8A80-BFD6FC06AF3A.thumb.jpeg.a6a3e750f6373712bb1ddf391e8a8c37.jpeg
  • 1 year later...
I originally was shooting for 450 to the wheels and met that goal and some thanks to E85 😈. Low boost 15 PSI 513WHP and 357 TQ. Due to stock tranny high boost is stopping at 20Psi and 569WHP 396 ft lb TQ. I’m very happy with these numbers and cannot wait to learn this new beast.
  • Like 1
  • 3 years later...
Upgrade time. Been a long time coming, but I was able to get my GTR to a reputable builder in the States. List of upgrade parts below:
RB30 (Sourced from Australia)
PRP RB30 timing belt kit with all options
Nitto pistons
Nitto I beam rods
Nitto oil pump
King engine bearings
New RB26 Head (Grabbed during Heritage run)
Kelford 272 cams mild lift
Supertech intake and exhaust valves over sized
Nitto Head gasket
Greddy Oil Pan Sump
GKtech fan blade and adapter
Koyo Radiator
Borg Warner S362 SXE
6boost turbo manifold T4 divided
Turbosmart wastegate Pro-gate 50 lite
ID1340x injectors
Radium external surge tank
Walbro 450 fuel pumps x2
All Parts in hand and awaiting my turn in line at the shop!
  • 9 months later...
2025 Update
PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop.
-700 to 800hp Service was done to the Block, which included:
  • Inspection
  • Prep and Black Brace to convert engine to 4wd oil Pan
  • Crank Fully prepped for 1000hp
  • PRP RB30 timing belt kit w/ ALL options
  • Nitto Pistons
  • Nitto I-Beam Rods
  • Nitto Oil Pump
New OEM Nissan RB26 Cylinder Head Shipped
  • Supertech intake and exhaust Valves over-sized
  • Kelford 272 cams Mild Lift
  • Nitto Headgasket
All of the machine work is completed and next step is assembly and dropping in the new motor.
Upgrades (Changes) from the previous build:
  • Engine Management - no longer using ECUMasters. Haltech Platinum Pro
  • Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E
  • Fuel - 1000cc injectors to ID1430x
    • Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s
I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
