Hey gurus. I have a bit of an issue..
s1 R33 Gts25t. Stock RB25DET .
Apparently has :
a hypergear turbo, EBay 50mms external gate with a screamer , boost controller, fuel pressure regulator, 3" exhaust and a big fmic and a forward facing plenum.
Now the issue is it's running really rich and fuel economy is completely stuffed. The bov has been removed and the pipes been routed to the back of the intake manifold. I have changed my Ecu and maf, and it's still the same.
I can unplug my tps and the car drives and.Runs normal, but if I unplug the maf the car stalls. Also if i squeeze the bov hose closed the car stalls... and honestly I'm lost as to where to look now.
Any help would be awesome thanks.
That whole setup is completely f**ked up.
The BOV return line routed to the back of the manifold is actually feeding the idle control valve.  Which is why it stalls if you crimp it.
You can't run a big turbo and altered fuel pressure etc etc against a stock R33 ECU.  It will tell you to go f**k yourself by making you fill up at every servo you pass.  This fits your description of your symptoms pretty well.  See above post.
thats what i was leaning towards haha , but ive not had time to look into the issues any further since i got the car. wheres the idle control meant to connect to? would be able to keep the hypergear turbo and sort out the bov/idle control piping?
The idle air control draws from the turbo inlet, via a combo of rubber and hardpipes that are attached to the original crossover inlet pipe arrangement.  The butchered plenum means that all that is gone, so the butcher found a way.  The BOV returns to the same place (turbo inlet, a separate port), so it's not incorrect for it to be hooked up the way that it is, just an ugly hack.
If you want a BOV back, you will need to attach it to the cold side intercooler pipe just before the TB and return it to the turbo inlet.  This is not strictly necessary - just depends on whether you like dose or like to have the inlet air bypass the turbo when on cruise (which is what it is actually for).
The main issue is the ECU.
54 minutes ago, Wrighty said:
thanks for help everyone, im thinking ill have to get a new ecu. but i still dont know why the car runs without the tps
Because the tps isn't a very important sensor for how 99. 9% of cars run
Original owner has wasted money on a FFP and a fuel regulator when what he NEEDED was bigger injectors and a tunable ecu...either a Link, adaptronic etc or for less money and a little investigation a Nistune set up.
  • 1 month later...
  • 7 months later...
fixed the IACV hose that was butchered by previous owner, also have worked out it just needs an ecu and a tune to sort the other issues out, has new coils and plugs now as well
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
