Hi All,
Please help me identify any speed issues you may be experiencing.
Do these issues occur at a specific time?
Do they occur on mobile or desktop or both?
Does the status bar (bottom left) say "loading ..." or anything while its loading? If so can you post what it is loading?
Anything else you may have noticed.
Thanks guys, the site has been fine for me so I haven't noticed it at all.
Christian
https://www.sau.com.au/forums/topic/474301-site-speed/
The speed issues im having are mostly when using pc. Mobile  app isn't lightning either but is ok. When on pc in the bottom left corner i get waiting for sau.com and then waiting for google ad services and after about a minute the next page will actually load. I have held off in saying anything till now in the hope it will resolve itself but that hasn't happened.
Cheers Bill
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878509
 Cheers Bill
Thanks Bill,
Can you keep an eye on it over the next day or two and let me know if it seems any better?
Thanks,
Christian
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878510
Thanks Bill,
Thanks,
Christian
No probs, im on mobile app atm and it seems to be faster than before, ill let you know how the pc goes when i get a chance to use it [emoji106]
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878529
I have been having issues connecting to SAU....all other forum sites I visit are fine, just SAU.  I sometimes get the DOS based view [blue text, and just a list of the forum pages] rather than the normal GUI forums page.
If I get the DOS view then I cannot open any other pages, it usually comes up with a blank screen.  If I leave and come back in 10-15 minutes its then usually OK.
The other thing that has just started to happen as well, the forums page comes up OK then it reloads straight away and I get a blank screen [address in address bar is still OK].
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878647
Wow! That all sounds really screwy!
Can you take some screen shots next time? This is really bizarre.
What OS / Browser are you using? Has it been different over the past 24hrs?
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878648
I'll take screen shots when I can...just now had to try to get into SAU 3 times...3rd time lucky.
Was Ok 1 or 2 days ago, didn't notice a difference till this morning tbh.  Still using IE...been lazy,  really should have gone over to Chrome or Edge.  Used to use Firefox but my virus checker was saying FF was out of date etc so gave up on FF.
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878682
10 hours ago, PranK said:
Thanks guys.
I've just made some more changes please keep the feedback coming if anything changes again.
Shortly after you made the quoted post, I could not reply to any threads for the whole afternoon.  The reply box at the bottom was grey and unresponsive.  Highlighting any text in a post did not bring a pop up "quote the selected" and there were no quote buttons anywhere.  I wouldn't normally say anything about this, because it has happened to me many times in the past (and yes, I was logged in), but the timing of you "making some changes" might be more than a coincidence.
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878687
Ok thanks for letting me know. It's some of the coad behind the reply box that has been changed so that makes sense but please let me know if it happens again (if it happens you can get me via the contact form or even via the Facebook page if PM's don't work).
https://www.sau.com.au/forums/contact/
Thank you!
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878688
  • 3 months later...
Thank you!
PM sent
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886029
For the last week and a bit ive been having issues where new and unread posts aren't showing. This is across the main site, app or Tapatalk. Sometimes a notification will show a new post but nothing is on site. Eventually when the posts show up, i can see there was posts made at the times i was not able to see anything. Im wondering if this is widespread or just happening to me.
Please check it out when you get a chance Prank. Thanks Bill [emoji106]
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886475
Yep seeing this too in the Android app.
Also experiencing this in the all posts view. No posts appear and then the posts sometimes appear after refreshing 10 times.
Rob
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886529
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
