 car is 1998 GTT R34, people in the USA can't give me a straight answer.
Example of email I got back from them:
James,
We are not 100% certain but the d-18 part number ought to be the correct one if I am not mistaken. Seen here:
https://www.enjukuracing.com/products/bc-racing-br-type-coilover-for-98-01-nissan-r34-gts-d-18.html
If they are un aware I wouldn't know what direction to point you in other then forums to see if the gts and gtt are the same for coil overs. Apologies for not being of more help. Let us know if you have any other questions or if you want to get a order going. Thanks!
Regards,
Brandon McDowell
Enjuku Racing Parts, LLC
Street | Strip | Show
Customer Service
[email protected]
Phone: 352-241-8399
Hours: 9:30-5:30, M-F, EST
So, who here has a R34GTT and can confirm these work.    I got a similar reply from BC Racing themselves.     I find this rather hilarious.
GTT uses a fork type rear mount
GTS uses a bushing
Ask for a photo of the rear shock mounting point at the base, pics in my build thread of what a GTT shock should look like here:
https://www.sau.com.au/forums/topic/463470-jordys-r34-gtt/?do=findComment&comment=7837425
  • Like 2
Jordy's info is right. I wouldn't buy from that site, especially if they list the R34 as a "GTS"
Grab a set from Justjap and get them shipped to the States, it all has to be shipped to the USA one way or another as it's all coming from Taiwan. That way you will absolutely get the correct part.
Right, but did you guys not read what I said.  BC racing told me they didn't know, and their reseller (a rather popular one in the US) also doesn't know.
I was asking if there was any owners that had them could verify what they ordered so I can get this squared away, and then get back to these companies, because either they hire idiots that don't know their products, or nothing works for the GTT.
They absolutely would know,  you wouldn't even need to contact JJ as much as you could buy the direct part from their site.
http://justjap.com/bc-racing-coilover-suspension-kit-nissan-skyline-er34-gt-and-gt-t-4ws-rear-fork-type.html
https://bcracingcoilovers.com/collections/nissan/products/99-02-nissan-skyline-r34-gts-rear-fork-bc-racing-coilovers
Not hard to look under your car at your current setup (whether it's eyelet or fork type).
You could have literally figured it out by the time you created this thread.
The company doesn't know because it slaps generic monotube dampers and springs onto hundreds of different types of mounts.
I know they are fork coilovers!  I've known for quite some time.  I was asking what part numbers actual owners used because I couldn't get a straight answer from BC, nor one of their biggest resellers.
So, I figured, taking the advice of the reseller, I would ask here from someone who ACTUALLY OWNS THEM before I order something that they can't give me a straight answer on.
  • 11 months later...
I used to run a giant nissan forum, so here I am updating my thread so it actually helps search engines.  I also made a 'tech' video that might help some people that are new to the R34 Chassis.  I ordered Stance coilovers from Enjuku Racing.  They work just fine!
It was still a little strange that nobody at Enjuku or BC racing could answer with confidence what part number I needed at the time.  So they just sent me a set and it turned out to work fine.   LOL
You're question was answered above? I don't see why this dragged out for so long.. Also for future reference to others, JJ won't sell BC products to overseas customers.
D-18 (Fork type)
D-72 (Eyelet type)
  • 3 weeks later...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
