Ok guys I got an issue I’d like to hear your thoughts on. I have a r32 gts-25 non turbo that I swapped a rb20det into a few months back. Also added split dump, full 3” TBE, nistune, wideband, and other gauges. So when warm it has always had a breakup in boost at WOT. It was getting to around 11psi on my boost gauge. So I also had a 45v1 rb25 turbo that I had planned to throw on when I was diagnosing the break up, since I would already have everything apart. This past weekend I installed the turbo and used the actuator off the 20. Replaced coil packs/ gapped to 0.8/ changed afm and still had the breakup. So tonight I was out driving. I pulled over and disconnected vacuum port to BOV to see if there was any difference, and boom, the misfire/hesitation under WOT was gone. She ran and drove great, even though it had flutter. But the weird thing is I am only getting 7 psi constantly even though I changed the actuator off the 20 that I personally have had hitting 11psi for months. I’m hoping the couple beers I’ve had this evening might be having me miss something obvious...sorry for the novel. Thoughts please!
https://www.sau.com.au/forums/topic/475432-need-help-on-r32-gtst/
If you disconnect a bov it will leak when there's boost in the system. Pressure helps keep it shut.
Do you have a wideband? If leaking boost out of the bov made it run right it would be crazy lean otherwise.
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
